It is currently Tue Apr 21, 2015 3:41 am
 Post subject: Interesting HDD issues (or how to kill you MFT)
PostPosted: Thu Mar 12, 2009 3:51 pm
While attempting to copy over files from my old EIDE drive to my spiffy new SATA drive, I plugged in the old drive as a slave on my IDE channel.
The computer booted and recognized the drive, only to go BSOD and reboot.
I then plugged the drive back in as a external USB drive only to find out the MFT was corrupt. I tried running chkdsk (from the cmd), TestDisk, and even tried to mount the drive in Linux (whole other thread).
Anyway, the point of this thread is determine what exactly I did wrong, and how not to repeat the mistake (for myself and others).
PostPosted: Fri Mar 13, 2009 3:28 pm
Why did you plug it in as slave? Was there a cd-rom above it as Master?
PostPosted: Sat Mar 14, 2009 10:02 am
Yep...
PostPosted: Sat Mar 14, 2009 10:21 am
Did you try running checkdisk with the r and f flags?
As in: chkdsk /r /f and point to the ide drive?
PostPosted: Sat Mar 14, 2009 1:01 pm
Yep, covered that in the first post.
chkdsk failed both from the GUI and the cmd.
I ended up running GetDataBack over 48 hours and recovered everything.
PostPosted: Sat Mar 14, 2009 2:27 pm
Most people that say they used checkdisk don't use the /r /f flags that is why I asked.
Good to hear ya got your data back!
