It is currently Tue May 21, 2013 11:01 pm
 Post subject: Aggregate nVidia GPU2 driver and client update information
PostPosted: Sun Jun 29, 2008 9:48 pm
team psycho or sumthin
I think this calls for a sticky so the information isn't "lost" among the other posts.
PostPosted: Sun Jun 29, 2008 9:49 pm
The current client:
http://www.stanford.edu/group/pandegrou ... -612b8.msi
Here are the direct links for driver 177.35 and they natively support 8xxx, 9xxx and GTX2xx cards.
Do to the format of the links, I have to use TinyURL:
XP32
http://www.nvidia.com/object/thankyou.html?url=/compute/cuda/2.0-Beta2/windows/driver/NVIDIADisplayWin2K(177_35)Int.exe
XP64
http://www.nvidia.com/object/thankyou.html?url=/compute/cuda/2.0-Beta2/windows/driver/NVIDIADisplayWin2KAMD64(177_35)Int.exe
Vista32
http://www.nvidia.com/object/thankyou.html?url=/compute/cuda/2.0-Beta2/windows/driver/NVIDIADisplayWinVista(177_35)Int.exe
Vista64
http://www.nvidia.com/object/thankyou.html?url=/compute/cuda/2.0-Beta2/windows/driver/NVIDIADisplayWinVista64(177_35)Int.exe
The page can be found here
Also, FahCore_11.exe has been updated, shut down the GPU2 client and go to
C:\Documents and Settings\<user name>\Application Data\Folding@home-gpu
and delete FahCore_11.exe, restart the GPU2 client and it will automatically download the new core.
ChelseaOilman wrote:
For Vista: "C:\Users\<your_windows_username>\AppData\Roaming\Folding@home-gpu"
PostPosted: Mon Jun 30, 2008 4:52 am
I'll add this to the Thread of All Threadslist.
PostPosted: Mon Jun 30, 2008 6:16 am
That's for WinXP.
PostPosted: Mon Jun 30, 2008 7:01 am
Cool, I'll keep an eye out at the nvidia and F@H forums for the updates :D
That's for WinXP.
LOL, forgot about Vista.
PostPosted: Mon Jun 30, 2008 8:34 am
I,m actualy running the 177.40 drivers now Since they enabled native PhysX support on the G92 cores.
Gameing comes first and a free upgrade on something I already own is nice.
On a side note these drivers fold just as well as the 177.35's no loss or gain.
