Watch the "I'm Staypuff and I Fold" video
Vote for November's PSOTM
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups    Ban PanelBan Panel   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Gigabyte GA-P35-DS3L be all thread
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic     Forum Index -> Overclocking and Cooling Corner
View previous topic :: View next topic
DANK68
PostPosted: Mon Feb 18, 2008 5:54 pm    Post subject: Gigabyte GA-P35-DS3L be all thread Reply with quote
Just put together a new 8400 w/ Gigabyte board 2gigs 1066
system. only know how to get the cpu to 3.15mgz. Gonna switch
to Asus P5k board if i cant figure it out.. Please help !!!
I dont know were to put the numbers
DANK
Back to top
View user's profile Send private message
heartagram
PostPosted: Mon Feb 18, 2008 6:11 pm    Post subject: Reply with quote
I have that same board with an E4500 in it. All the tweakings and what not are in the M.I.T. section of the BIOS. Just make sure you go into the Advanced BIOS Features section and turn off all the Clock lowering safety features like CPU Enhanced Halt(C1E), CPU Thermal Monitor(TM2), CPU EIST Function and what not. Also I would recommend turning the CPU SmartFan Nonsence off and always have CPU Fan on High. I do this on mine as my system is in the living room with the television and all that so fan noise isn't a big deal for me. Wink Maybe it is for you. Also when you are actually OC'ing, Set CPU Host Control to enabled, and change the CPU Host Frequency to get what you're looking for. I wouldn't mess with the automatic OC'ing feature that the board has. Just do it yourself right? Wink Also, up to you about changing voltages and whatnot, but all you have to do is turn off the automatic system voltage control and just tweak the settings to your little heart's desire. Very Happy Anyhow, I hope that I helped you a lil bit. Just post some more if you need anymore help. I'll try to help out and I know lotsa other people here can help more too. Cheers.
Back to top
Chumly
PostPosted: Mon Feb 18, 2008 6:18 pm    Post subject: Reply with quote
This BIOS has some very strange terms. Like they're trying to coin their own words just to be different. Can one of you guys just take a picture for shear curiosity please. It'd be much good.
This is the normal wording commonly seen in a BIOS' section you'd OC within:
Why making up "Host Frequency" instead of the actual "Front Side Bus" is needed is disheartening. It feels like Fisher Price where they're undermining what we can understand.
Back to top
View user's profile Send private message Yahoo Messenger MSN Messenger
Newbie1Kenobi
Team Member Top 100
Team Member Top 100
PostPosted: Mon Feb 18, 2008 6:40 pm    Post subject: Reply with quote
Another thing to do..and it's pretty annoying. When you first boot into the BIOS, you don't have access to all the variables you can control, specifically voltages IIRC. Boot into BIOS, press Ctrl+F1, then go to your M.I.T section.
I don't know why Gigabyte put that extra step in there. Rolling Eyes
Back to top
View user's profile Send private message Send e-mail Visit poster's website
heartagram
PostPosted: Mon Feb 18, 2008 6:41 pm    Post subject: Reply with quote
Okies here some pics of the BIOS. Umm i think this is a good thread for me as well because I have the idea and concept of OC'ing but I can't seem to do it right. So yes in the pics, my comp is running stock. Sad anyhow here you go.
This is the Main Page for the BIOS.
This is the actual OC section.
This is the PC Health section.
This is all the safety crap section. Evil or Very Mad
This is another pic of the main screen (with the flash)
Anyhow hope that helps chumly and ultimately, Dank Very Happy.
Back to top
DANK68
PostPosted: Mon Feb 18, 2008 6:46 pm    Post subject: Reply with quote
Appreciate the fast repley.
Can someone give me a screen shot of the tweeks in the M.I.T
section of the bios for a 8400
Thanks everyone
DANK
Back to top
Chumly
Well it helps to understand what you guys are working with, so thanks for that!
But it's shear crap what they do! There's 20 things wrong with that BIOS, and dislike that board even more now.
Just an easy example is the Memory Voltage. If you wanted 2.1v, what would you set? There's no reference. You'd have to first see what you're currently running since the SPD is in Auto and then boost it from there. It'd take me 3 boots to get the setting I wanted when I could just type in "2.1" in a normal BIOS. If you're memory boots at 2.1 by SPD and the JDEC standard is 1.8...would putting +.1 in there be 2.2 or 1.9? It's nuts how that thing is convoluted.
Back to top
Newbie1Kenobi
Team Member Top 100
Team Member Top 100
PostPosted: Mon Feb 18, 2008 7:00 pm    Post subject: Reply with quote
I think, you can do it in two, Chumly. Check the Memory voltage in PC Health, then navigate back to the M.I.T section and bump it up accordingly. Then reboot and double check.
Of course it is possible that I didn't fully understand your post....my apologies if I misunderstood.
Back to top
heartagram
PostPosted: Mon Feb 18, 2008 7:22 pm    Post subject: Reply with quote
Im hoping you guys can figure out what to do to help this guys because I've figured out the concept of OC'ing. But Chunmly knows that I can't quite get it to stay good or something. Anyways last night I was typing a post similar to what dank is talking about and then before I posted it IE closed itself... Evil or Very Mad Anyhow, I really want to OC and get my juice but the numbers on benchmarks turn out worse in some cases and in others only marginally better than stock. So hopefully everyone gets some help around. Also, I set my CPU for 2.96ghz (266x11) and it boots and all that but in 3dmark06 my comp crashes... Sad anyways I gotta go for now but hopefully everything works out kosher for everyone. Very Happy Thanks chumly, dank, and kenobi.
Back to top
Chumly
PostPosted: Mon Feb 18, 2008 11:15 pm    Post subject: Reply with quote
No, you didn't understand it at all. You tell me 4 steps to take. In a regular BIOS, You just click the memory voltage and set it to what you want. No BS, no hit and miss. Just tell it what to do and it does it. No steps. Just type the number in. PC health for a normal BIOS would be how it's doing...temps and volts. Not actually changing them.
Is this thing AMI???????????????????????????????
This is the same pic for both Abit and Asus p35 BIOS. Why Gigabyte wants to be different, I dunno. I just think they're doing the old "happy fun wow over mega clock it fun boy" thing. Just call it what it is, we'll work with it. The more the "simplify" things, the harder it gets. It's a basic computer. Don't change words based on kindergarten feedback.
Back to top
Newbie1Kenobi
Team Member Top 100
Team Member Top 100
PostPosted: Tue Feb 19, 2008 8:34 am    Post subject: Reply with quote
Chumly, I never said it would take fewer steps..you said you needed 3 boots I said I can do it in two. The PC Health section is the same on the Gigabyte boards as others. It reports only what the current settings are, voltage, temps, etc. No variables there to change.
Semantics aside ( I think that's what we're arguing about here anyways Wink) I've included some BIOS shots from my board. It's a Gigabyte GA-P35-DS3L, rev 2.0. I've included the basic MIT section as well as the advanced features that are unlocked when you hit Ctrl+F1 in the main BIOS screen (page 31 in the manual.)
Normal MIT screen:
Extra "Easter Eggs" Unlocked:
Second half of Advanced Screen:
As soon as I get some better RAM in here, I'm gonna start ramping this Q6600 up. So, I'll probably be posting some questions in here, one of which wil NOT be: "How fast will this go?" Laughing
So, why does Gigabyte, or any other company feel the need to "spruce up" their BIOS sections with new fangled terminology, anyways? Is it just to set themselves apart from the other manufacturers?
Back to top
00john00
Team Member Top 100
Team Member Top 100
PostPosted: Tue Feb 19, 2008 11:39 am    Post subject: Reply with quote
http://en.wikipedia.org/wiki/Reinventing_the_wheel
http://www.maximumpc.com/forums/viewtopic.php?t=72463&highlight=gigabyte
You will need to change you SPD to a higher #.
They hide the options in hopes that people will pickup their User's manuals and READ Shocked Shocked PG 33 Wink
You're right but its not that hard once you know how. The board default is 1.8. I've read 1 review that stated it set the correct voltage (Memory Support List Confused ) You can see the voltages in the PC Health Section.
I hope you put those OCs to good use! We need the help!
Back to top
DANK68
PostPosted: Tue Feb 19, 2008 1:07 pm    Post subject: Reply with quote
Have a screen shot of my bios (dont know how to up load)
Any how I changerd the system memory multiplier to "2" then
changed the cpu clock ratio from 9 to 8.. Managed to get to 3.5mhz
without any other changes..I guess im pretty happy, as I dont want to pust it
I have Corsiar dominator for memory "1066"
any comments?
DANK
Back to top
msnight04
PostPosted: Wed Feb 20, 2008 3:40 pm    Post subject: Reply with quote
I'm not trying to steal this thread or anything, but I'm curious as to why this is a sticky?
Back to top
Newbie1Kenobi
Team Member Top 100
Team Member Top 100
PostPosted: Wed Feb 27, 2008 5:00 pm    Post subject: Reply with quote
I'm going to record my attempts to push my Q6600. I have no preconceived goals here, just as fast as I can get it with stability and decent temps.
Parts:
1-Q6600 stock 2.4 Ghz
1-Thermaltake MaxOrb CPU cooler.
2-1GB OCZ Platinum Edition, revision II PC-6400 RAM
1- X1650 Sapphire Radeon video card
1-320Gb HDD
1-Antec 900 with negative pressureWink One exhaust fan at back(120mm) one exhaust fan on top (200mm), two intake fans in front(120mm each), all set to medium.
First, I made sure that I was fairly happy with my stock temps. CoreTemp records around 26C idle/45C at full load which the BIOS seems to agree with.
I had to manually set my timings for my RAM to run (thanks to the guys at the OCZ forums) without crashing. Done!! Now on to the real fun.
I've got a thermometer on the case to monitor the ambient temperature around the case..pretty steady around 22C.
I booted into the BIOS and bumped the FSB (or CPU host frequency, as Gigabyte likes to refet to it Rolling Eyes) from stock setting of 266Mhz to 271. A modest jump that saw me go from 2.4 Ghz to 2.44 Ghz.
I ran Folding at Home to test for stability while I did some errands. I returned home and
OH NOES!! A BLUE SCREEN
It was a PFN_LIST error. I Googled it and found it seems to be memory related. I had my RAM voltage set to 1.9...below the recommended minimum of 2.0V. On the Gigabyte board it is +0.3, the board defaults to 1.8 I know the math adds up to 2.1V, but the BIOS says 2.0V
I'm running Memtest now and if it passes, I intend to fold for 24 hours before ramping up again...stay tuned!!
Back to top
Newbie1Kenobi
Team Member Top 100
Team Member Top 100
PostPosted: Thu Feb 28, 2008 9:51 am    Post subject: Reply with quote
24 Hours later:
Folded all night with no errors or crashes, so I've rebooted into the BIOS and upped my FSB to278. With a 9X multiplier, I'm now running at 2.5Ghz. Idle temps have gone up to about 30C. I've turned the exhaust fan on the back of the case to high, and they dropped by about 2C.
Under load, they are around 44C with an ambient temperature of about 21C. Folding for another 24 hours for stability. As I get higher up, I'll probably switch to Prime 95 or some other sort of stress test.
A quick question about fans here. Assuming I end up turning both exhaust fans up to high, would it make any sense to turn the intake fans down, creating a higher negative pressure area within the case? Or is there some point at which it becomes moot, and the only way I can find out is to *gasp* try it out for myself?? Shocked
Back to top
00john00
Team Member Top 100
Team Member Top 100
PostPosted: Thu Feb 28, 2008 10:12 am    Post subject: Reply with quote
I always prefer that method Very Happy
Kick it up to 333 or even 350 FSB if you feel lucky & raise the CPU Voltage a little. 1.37 will get both of my Q6600s and many others to 3.2 and Prime95 stable.
Switch to Prime 95 to test the CPU Voltage. Reduce it if possible & watch the temps. What's the SPD/ Memory Frequency??
Back to top
Newbie1Kenobi
Team Member Top 100
Team Member Top 100
PostPosted: Thu Feb 28, 2008 10:23 am    Post subject: Reply with quote
Right now, my, memory is at 834 Mhz (278 FSB x 3.0 Memory multiplier) Apparently that OCZ RAM is pretty sweet for overclocking!! Very Happy
Back to top
00john00
Team Member Top 100
Team Member Top 100
PostPosted: Thu Feb 28, 2008 10:30 am    Post subject: Reply with quote
Try changing the System Memory Multiplier (SPD) to 2. You can tighten the timings & maybe reduce the DDR2 OverVoltage Control too.
Back to top
Newbie1Kenobi
Team Member Top 100
Team Member Top 100
PostPosted: Fri Feb 29, 2008 12:09 pm    Post subject: Reply with quote
Okay...another 24 hours have passed and I'm at it again. Bumped the FSB up by 10Mhz this time. I'm now running at 2.6Ghz.
I lowered my memory multiplier to 2.5 which has my RAM running at 720Mhz.
With a room temperature of approximately 21C, temps are still holding around the 44C mark. Folding is up and running.
00john00...tighter timings=raising or lowering the timings? Currently, it's running at 4-4-4-15 at 2T. So, a looser timing would be 5-5-5-16 at 2T...just as an example?
EDIT: Just retested the computer under Vista's Experience Index, or whatever it's called. At all stock settings, my CPU score was 5.9 and my RAM was 5.6. At 2.6Ghz and 720 Mhz (CPU and RAM speed respectively) I now have a CPU score of 5.9 and a RAM score of 5.8. Interesting.
Back to top
Display posts from previous:
Post new topic   Reply to topic     Forum Index -> Overclocking and Cooling Corner All times are GMT - 8 Hours
Page 1 of 4
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Future © 2008 Future US, Inc. All Rights Reserved.
