Watch the "I'm Staypuff and I Fold" video
Vote for November's PSOTM
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups    Ban PanelBan Panel   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Project ~ Venimus, Vidimus, Vicimus ~ completed 2-16-08
Goto page 1, 2  Next
Post new topic   Reply to topic     Forum Index -> Modders' Workshop
View previous topic :: View next topic
XcaliburFX
PostPosted: Wed Oct 24, 2007 6:45 am    Post subject: Project ~ Venimus, Vidimus, Vicimus ~ completed 2-16-08 Reply with quote
Ok, I am Co-Leader of a UT/CS:S gaming clan and I have started a new project based on the clan logo and games we play. To be honest I am not sure just what direction this project will take lol. I intend to have it completed between Thanksgiving and Christmas. I am planning a simple low level project, but I never know one minute from the next what I might do. lol Because ......... If you break it, you mod it. Wink
I am starting with a Chieftec Dragon steel case.
The case is in great shape other than a few cosmetic flaws. This very sturdy case will make a great start.
Open wide, here comes the drill!!! Wink
No, I’m not a dentist, nor do I play one on TV. lol
Oh no what have I done!!! Wink
Just a few more rivets to go.
Disassembeled and ready for whatever may come.
Ok, looks like things are in great shape. Let’s make them even better. Smile
Back to top
View user's profile Send private message Visit poster's website
DreadedOne509
Airborne All The Way!
PostPosted: Wed Oct 24, 2007 9:41 am    Post subject: Reply with quote
I've seen many great mods that have started with that exact same case.
Seems to be a favorite of a lot of people.
Love drilling the rivets out and taking apart the cases almost as much as
altering them and re-assembling.
Good luck, look forward to seeing some progress soon.
Back to top
XcaliburFX
PostPosted: Tue Nov 06, 2007 5:51 pm    Post subject: Reply with quote
Been pretty busy so, updates will be slow for a tad.
However, I decided to add a blowhole and was able to get that cut today.
There she blows!!!
Decided to add an 80mm blowhole to the case. Here's the starting hole.
Got Jiggy With It. Wink
Cut out the blowhole with the jigsaw and then cleaned up the burs.
Test Fit
Checked the opening, and I think after some minor smoothing out, it’ll be perfect.
More to come. Smile
Back to top
redrum00
PostPosted: Thu Nov 08, 2007 7:20 pm    Post subject: Reply with quote
You really Leatherfaced that case with the drill. Keep posting.
Back to top
XcaliburFX
PostPosted: Thu Nov 08, 2007 8:06 pm    Post subject: Reply with quote
LOL< most of that is where the scroll saw scratched the paint from the case. Once I sandblast it all scratches will disappear. I do need a new scroll saw though, mine seems to be getting rough. lol Wink
Thanks,
~X~
Back to top
Mobius
Location: Someplace between here and there... I think... I dont know anymore...
PostPosted: Thu Nov 08, 2007 10:00 pm    Post subject: Reply with quote
You could also invest in a hole saw that hooks up to your drill. So much easier and cleaner of a finish.
Back to top
View user's profile Send private message MSN Messenger
XcaliburFX
PostPosted: Fri Nov 09, 2007 4:42 am    Post subject: Reply with quote
Well, the thing is I have a hole saw and that is normally what I use, however, it has grown legs and walked away it seems, as I could not find it. lol Of course being the "patient" man I am, lol, I couldn't wait till I found it or bought another. At anyrate, the hole is pretty close to being a perfect circle and with a tad of touching up with the dremel grinding wheel, it will be perfect.
Thanks,
~X~
Back to top
XcaliburFX
PostPosted: Thu Nov 29, 2007 6:36 pm    Post subject: Reply with quote
I had originally wanted to have the side panel and fan grills laser cut with my clan logo. That however, ran into several obstacles, mainly no one to do it. Also, the side panels I ordered were sent windowed instead of solid. So, I decided on etching part of my clan logo into the acrylic. Tonight, I attempted to do just that. Below are a few pics of the acrylic before and after.
Disassembled and ready for fun. Very Happy
The metal of course is the wrong color, but no matter so is the rest of the case. lol
One last look before things get ugly.
Laid out the stencil in photoshop, printed it, cut it out and applied it to the waiting window.
Not too bad for my first attempt at etching.
I used my sandblaster to do the etching. I did find a scratch or two that may need polishing out, but nothing major at all.
Back to top
DreadedOne509
PostPosted: Thu Nov 29, 2007 7:28 pm    Post subject: Reply with quote
Very nice.
What did you use as a medium for the stencil?
Back to top
XcaliburFX
PostPosted: Thu Nov 29, 2007 7:39 pm    Post subject: Reply with quote
Thanks Smile
I used an inkjet vinyl decal material and medium grit sandblasting sand. Now, of course using this, I had to be several feet from it, as it is a bit too rough for it up close lol.
Back to top
XcaliburFX
PostPosted: Fri Dec 14, 2007 4:14 pm    Post subject: Reply with quote
Ok, with things just not going my way with the special metal work I was getting done, I have decided to move on to take a different route. On the front panel I am going to be using 18 gage copper plate. Instead of inlaying it. like I had originally planned. I am going to use it to cover the center section of the front panel. I will possibly engrave it as well. Wink Here are a few pics of the initial cutting process.
First I made a template of the center.
Drew out the cut lines. Wink
Now to make the first cut.
So, far so good.
Now after the first piece is cut I test fit it to the door.
It is looking pretty good.
Now, cut the second section out.
At last, the final cut.
Now I test fit both pieces.
Oooooh, now I am liking the looks of this. Note; I skipped the first rung on the louvers and left the bottom edge, I did this for lighting effect. I hope. lol All in all, I think I made the right choice given my options at hand. lol
Perhaps I will add some engraving. Smile
Back to top
Massimo
PostPosted: Sat Dec 15, 2007 12:27 pm    Post subject: Reply with quote
Looking good. Please keep the updates flowing, this build has lots and lots of promise.
Back to top
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
XcaliburFX
PostPosted: Tue Jan 01, 2008 2:19 pm    Post subject: Reply with quote
Ok, missed a few pics and an update, cam was down. At anyrate, here are a few pics after paint and some reassembly. Still not done, but I'm getting there. Wink
Little copper Alien Heads for aesthetics. Was going to use them to attach the copper plate, but the studs were too short.
Bottom side of blowhole and Antec red Led fan.
Top view of case and blowhole, ended up using a BioHazzard fan grille since I could not get mine custom cut. Sad
The rest of the pics are just of the case chassis. I still have to do some touch up spraying for the side panel openings and any scrathec that may have happened, but I am pleased. The side panels have also been sprayed to match the top of the case. They were drying so no pics yet, but they look great. Smile
The front panel still has a way to go yet, and I have ran into a snag finding some more chieftec drive bay covers. Yes, frozen cpu has them, but I ain't about to pay 9 bucks each for them lol. So, I may have to fab some. Smile
Until next time Smile
Back to top
XcaliburFX
PostPosted: Mon Feb 11, 2008 2:36 pm    Post subject: Reply with quote
Finally some dry weather and warmth. lol Got the copper plate attached and clear coated plus the front bezel painted. Fans are all installed 5 in total all Red LED. After a bit of drying time I will mount the alien heads and etc etc. and finish this puppy up. Smile
Back to top
UnLawFulGod
PostPosted: Mon Feb 11, 2008 5:23 pm    Post subject: Reply with quote
That copper looks AMAZING! Are you going to de-sticker the blowhole fan? I think it distracts from the cool look of the case.
Back to top
XcaliburFX
PostPosted: Mon Feb 11, 2008 8:03 pm    Post subject: Reply with quote
Thanks!! Will probably cover that with carbon fiber. Smile
Back to top
XcaliburFX
PostPosted: Sat Feb 16, 2008 11:19 am    Post subject: Reply with quote
Well, I think it's all finished. That is unless, I add some tiny something another before I ship it to the clan member we decided to award it to. lol At any rate ...... here ya go the finished case.
I know I skipped a bit of the worklog update here at the end, but I got way busy and well I just plain didn't have time lol. I sure hope the Clan member likes the case. Shocked
Back to top
avanish11
Team Creamsicles
Team Creamsicles
PostPosted: Sat Feb 16, 2008 12:04 pm    Post subject: Reply with quote
wow it looks great!
Back to top
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger
transporter45
Team Member Top 100
Team Member Top 100
PostPosted: Sat Feb 16, 2008 2:17 pm    Post subject: Reply with quote
Great job man! That is a awesome award! Razz
Back to top
beteks
PostPosted: Sat Feb 16, 2008 3:53 pm    Post subject: Reply with quote
Nice Job!!! Very Happy
Back to top
Display posts from previous:
Post new topic   Reply to topic     Forum Index -> Modders' Workshop All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Future © 2008 Future US, Inc. All Rights Reserved.
