It is currently Mon May 20, 2013 7:48 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 296 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
 Post subject: 8800GTX, will it fit in your case? ***CLOSED DO NOT BUMP***
PostPosted: Wed Nov 01, 2006 10:57 pm
Cases that do not fit the 8800GTX
ThermaltakeTsunami
CoolerMaster Mystique
Gigabyte 3D Aurora
Antec P180
LianLi PC-65 (It will fit one card but not two in SLI)
LianLIPC-3077 (It will fit one card but not two in SLI)
Asus TA-210 (It's never going to fit in this case)
Thermaltake Soprano
Raidmax Sagitta (Is never going to fit the 8800GTX)
Thermaltake Armor Jr.
Thermaltake Aquila
Thermaltake Matrix VX
Cooler Master Ammo
Cooler Master Centurion 534
iStarUSA Nitro AxS-10000 (The 8800GTX is never going to fit in this case)
Silverstone LC18
NZXT Transformer
Antec P160
Cases that do fit the 8800GTX
Lian Li V2000-2100 series
Silverstone TJ07
Silverstone TJ09
Apevia X-Pider
CoolerMaster Centurion 5
EnermaxCS-5271BFS
Thermaltake Armor
CoolerMaster Praetorian 730 (it's really close)
CoolerMaster Stacker 830
CoolerMaster WaveMaster
NZXT Lexa "Retro toaster"
ChenmingCMUI-601 (you will have to remove the lower hard drive cage)
XION Solaris (will fit the 8800GTX but you will not be able to mount hard drives in the lower drive cage)
ApeviaX-Cruiser (It is really close but it will fit, but you might not be able to mount hard drives on the bottom cage.)
NZXT Apollo (If the 8800GTX is really 10.5 inches long it will fit.)
Thermaltake Shark(Only if the 8800GTX should fit if it is 10.5 inches and not 11)
Thermaltake Mambo (Will fit the 8800GTX, but you will not be able to mount all of the hard drive cage.)
Gigabyte GZ-FA1CA
Antec PlusView 2
XG CA-SW2-K (you will have to replace the included PSU)
Lian Li V1100
Lian Li PC-75
Antec 900
XION Onyx
AMSCF-2229BK
If your case is not on the list read this
If you are purchasing a 8800GTX in the near future, make sure it fits in your case. If you are wondering if it fits in your case, post a link to it and I'll post a pic of how it will fit.
Thanks to [H]ardforums Hurin for the idea for this thread.
Lian Li V2000-V2100 series
PostPosted: Thu Nov 02, 2006 2:59 am
Here's mine: Apevia X-Pider full-tower -
http://www.apevia.com/product.php?pid=142
PostPosted: Thu Nov 02, 2006 5:23 am
No it wont. I have a Gigabyte Aurora, which is not exactly small.
Fuck you very much Nvida.
R600 better be smaller.
PostPosted: Thu Nov 02, 2006 9:22 am
AMD64Blondie, here you go.
ApeviaX-Pider
Silverstone TJ07
Lian Li PC-65 owners are out of luck it won't
fit with that hard drive cage.
Post some more links if you want to see if it fits.
PostPosted: Thu Nov 02, 2006 10:10 am
im assuming that if they fit in the tj-07, that they'll also fit in the tj-09????
is this a correct assumption, or am i just making an ass out of....
ken
PostPosted: Thu Nov 02, 2006 10:39 am
ken
Yes, it will fit. Here is the proof.
Silverstone TJ09
PostPosted: Thu Nov 02, 2006 11:49 am
How about my Enermax CS-5171LBFS-B ?
PostPosted: Thu Nov 02, 2006 1:11 pm
It should fit. I could not find your case but I found another Enermax case that might be the same.
EnermaxCS-5271BFS
Does that solve your problem?
Thermaltake Armor
Cooler Master Mystique won't work with the 8800GTX.
Gigabyte 3D Aurora won't work with the 8800GTX.
Antec P180 won't work with the 8800GTX.
PostPosted: Thu Nov 02, 2006 1:15 pm
http://www.newegg.com/Product/Product.a ... 6811133154
Do your "worstest!"
PostPosted: Thu Nov 02, 2006 1:22 pm
Desperado81 wrote:
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
Do your "worstest!"
That case is already posted, and the 8800GTX does fit in it. Lucky for you.
PostPosted: Thu Nov 02, 2006 1:45 pm
Thermaltake Tsunami?
Anyways, how did you come up with that size for the 8800 GTX?
PostPosted: Thu Nov 02, 2006 2:13 pm
If the Armor didn't fit I was gonna scream, it's one of the biggest cases ever.
PostPosted: Thu Nov 02, 2006 2:20 pm
The motherboard photo I'm using was 377 X 351 pixels, and the size of the board is 12 X 9.6 inches. So I calulated that the board is 304.8 X 243.84mm.
Then I divided 377 by 304.8mm, so I figured out that 1mm = 1.23687664 pixels
The 8800GTX is 280mm long with 35mm cooler, so I multiplied 280 X 1.23687664 to get (rounded) 350 pixels. After that I copied two 350 X 15 rectangles the the motherboard photo and pasted them on, the same goes for the cooler exept it was wider and thicker.
Thermaltake Tsunami does not fit the 8800GTX. It's just a tad to big I'd try the 8800GT, at 24cm long.
PostPosted: Thu Nov 02, 2006 2:57 pm
That card will fit in any case owned by someone man enough to use a dremel.
PostPosted: Thu Nov 02, 2006 3:22 pm
It will fit in the P180 just fine if you take out the HD cage (which slides right out). Most people probably use the lower HD cage anyway to keep the heat out of the upper chamber.
PostPosted: Thu Nov 02, 2006 3:24 pm
Good point little guy, but not everyone wants to mod there case. I personally don't mind modding, if it looks good... Then again my case already fits the 8800GXT :P
PostPosted: Thu Nov 02, 2006 4:05 pm
CoolerMaster Praetorian 730 is cutting it really close.
CoolerMaster830
AsusTA-210 never going to fit in this case.
CoolerMaster Wave Master
Lian Li PC-3077
PostPosted: Thu Nov 02, 2006 8:01 pm
Here is a comparison
image from THG.IT
PostPosted: Thu Nov 02, 2006 9:44 pm
Million Club 2+ [PC]
CHENMING CMUI-601AEB-AW
this is what mine looks like, not sure if it is the exact one thou, I bought mine like 2 years ago.
note: edited link
PostPosted: Thu Nov 02, 2006 10:06 pm
hey nuke, just wanted to say thanks for all the work you've done for us in this post! i think you pic just sold me on the tj-09. thanks again!
ken
