It is currently Sun Apr 26, 2015 9:36 am
 Post subject: OS X 10.4 install disk
PostPosted: Fri Aug 14, 2009 5:47 pm
Monkey Federation (Top 10)*
I bought a used iBook that has Panther installed. It is a ppc 800 mhz so nothing special and most likely will not run Leopard very well. Any one have an old copy of Tiger they are not using?
I think I would need either the retail disk or an iBook specific version.
PostPosted: Fri Aug 14, 2009 6:33 pm
TravBv2.0
TravBv2.0
I think I have OS 8.5 somewhere around here. :lol:
Have you tried installing Leopard or are you just speculating how badly it might run. There should be options to disable some resource-heavy things like desktop-effects and such.
PostPosted: Fri Aug 14, 2009 6:47 pm
lol, I think you missed the part about it being a 800 mhz ppc. It has the maximum of 640MB RAM so I can only imagine how poorly leopard would run.
I have access to a Leopard install disk at my job but I thnk I will be better off with Tiger.
