It is currently Sat Jan 24, 2015 8:23 pm
 Post subject: Need some help with my project.
PostPosted: Sun Aug 09, 2009 9:32 am
I made a simple program that produces various Mortgage information. I added a menu to it and want to make my program print out (from a printer) the information from the listbox.
Here is a picture of the program:
PostPosted: Sun Aug 09, 2009 9:34 am
With a bit less information, we'd be even more confused!
Seriously .. what do you need help with?
PostPosted: Sun Aug 09, 2009 9:56 am
??? Its on my post. I said i need help with printing the contents inside the listbox. You see that picture i posted above; its a picture of my program. You see where it says "File", "Print"; when the user press "Print", it prints out the data from inside the listbox to the printer. So in the end the data inside the listbox will be printed on a 8.5 by 11 paper.
PostPosted: Sun Aug 09, 2009 9:58 am
You didn't even tell us what language you're coding your app in nor what problems you're having with printing.
Please .. you really need to be more specific.
PostPosted: Sun Aug 09, 2009 10:02 am
C#. I don't know how to make the "Print" button print.
PostPosted: Sun Aug 09, 2009 10:40 am
7yrs+11,000 Posts
7yrs+11,000 Posts
http://tinyurl.com/ox6v8o
PostPosted: Sun Aug 09, 2009 11:25 am
That first link of what Gamer linked to is really good.
