It is currently Thu Feb 26, 2015 10:27 pm
 Post subject: Can't load avatar
PostPosted: Thu Jul 23, 2009 9:15 pm
I tried looking for a support contact for the website but all I saw was magazine support so I figured this was my next best choice for my problem. A few weeks back I uploaded an avatar but I didn't like the way it scaled, so I deleted it and attempted to upload another. Now any time I try to upload an avatar I am greeted with the following error.
* The selected file /tmp/tmp_4MrFks could not be copied.
* Failed to upload the picture image; the avatars directory doesn't exist or is not writable.
I have tried several different browsers and files but I get pretty much the same message. Not having an avatar won't kill me, but I want to be able to show off my geekiness in its full 25x25 glory.
PostPosted: Thu Jul 23, 2009 9:19 pm
Monkey Fed [PC]
Monkey Fed [PC]
Are you trying to upload it from your machine itself? It usually works better if you host it in a place like Photobucket and link it from there.
PostPosted: Fri Jul 24, 2009 6:59 am
Joo can't haz one!
Avatars
When you hit 100 posts, sent a PM per instructions.
*edit* Wait! You had one before?
PostPosted: Fri Jul 24, 2009 7:29 am
Team Dino
Team Dino
It sounds like he's talking about the website, not the forums.
n0b0dykn0ws
 Post subject: sorry
PostPosted: Tue Jul 28, 2009 12:41 am
Sorry, yes I was referring to the website avatar. I post frequently there and did have an avatar. Only ran into this problem when I tried to change it. Since I couldn't find any website support links I thought I would try here. Sorry if this wasn't the right place to ask the question.
PostPosted: Tue Jul 28, 2009 10:59 am
Maximum PC Editor
Maximum PC Editor
Thanks for the heads-up. It's in the buglist, and should be fixed when we roll out our point release in a week or so.
 Post subject: Fixed!
PostPosted: Wed Jul 29, 2009 9:08 pm
Try your avatar change again. Should work now.
PostPosted: Sun Oct 18, 2009 10:07 pm
This has happened to me today. Can someone fix this for me?
