It is currently Mon Apr 27, 2015 11:03 pm
 Post subject: Essential skills for a *nix user
PostPosted: Tue Jul 21, 2009 6:39 pm
TravBv2.0
TravBv2.0
I need some advice for my blog. I've almost covered basic terminal use and I wanted to make some posts on essential skills that every *nix power user should have. What skills do you think are essential to a competent *nix user?
PostPosted: Tue Jul 21, 2009 7:12 pm
sudo chmod -R 777 /
PostPosted: Tue Jul 21, 2009 7:13 pm
RTFM
..and no, I'm not kidding.
To elaborate though, I'm thinking more along the lines of how to compile stuff when you end up with source.
PostPosted: Tue Jul 21, 2009 7:15 pm
http://nixiepixel.com/blog/blog7.php
PostPosted: Tue Jul 21, 2009 7:22 pm
I'd hit it.
PostPosted: Tue Jul 21, 2009 7:30 pm
How to install useless eye candy?
PostPosted: Wed Jul 22, 2009 1:37 am
TravBv2.0
TravBv2.0
furball146 wrote:
I'd hit it.
This!
I wanted to delve into some common thungs that Linux users tend to know, but isn't exactly SysAdmin stuff. Things like installing apps manually (tarball and source) compiling your own kernel, or general Linux troubleshooting. I was hoping to make something more of a good list of things a compettent Linux user should know.
SpaceBison, useless eye-candy isn't hard to install and configure. Plus, it's useless like you said. :)
PostPosted: Wed Jul 22, 2009 3:34 am
furball146 wrote:
I'd hit it.
inorite? Kinda bummed I haz no chance (and I am getting married in <3 months...) That would have been so epic.
Of course, she probably has a man and is only not mentioning him to boost her popularity. Sneaky woman!
PostPosted: Wed Jul 22, 2009 4:26 am
Monkey Federation (Top 10)*
WWLD? (What would Lodis do?)
From the sounds of things they are not expecting you to write perl programs on the first day. It sounds more like they want to see what you know and if they would consider you trainable.
I would make sure I know my way around the command line. Many (read: almost all) linux support channels revolve around ssh sessions and you will need to know how to navigate. I don't mean type all paths from the root i.e. /home/me/dir1/dir2, etc... Learn to be comfortable with relative paths. if you need to copy a file from the parent directory just use "cp ../filename ." don't type out the full path to everything; knowing how to use relative paths is one thing that shows you have an understanding of how the command line environment works and is structured.
Pick your favorite text editor and get good with it in a terminal window. Nano, Pico and the like are fine as long as you know the weaknesses of them and understand that they are not part of every installation. Vi or Vim has a pretty steep learning curve but the advantage is you can find one or the other on almost every distro by default.
Understand devices /dev/ttyX, /dev/ttysX, /dev/srX, where X is the instance. Don't worry about how to configure and setup but know what they are used for in general. Oh yeah, learn and love the 'screen' command.
Compiling software and fixing dependencies is also going to be important but probably not the main focus of a skills eval.
Get familiar with sed, grep, mv, cp, cd, ls, tr, tar, and any other common scripting tools. Don't just know the names and what they mean, learn the switches and when to use them. No one wants you to open a man page every 5 seconds to look up the switch to make the grep case insensitive or to see what the syntax for the cut command is.
Beyond that, a good general knowledge of what the /var, /etc, /usr, /, /boot, /bin, /sbin, /proc, and /sys are all used for would be mandatory. you start installing compiled software to /proc and I think the test would be over.
Know how to control runlevels and where to start/stop/restart services. Not just using the Red Hat 'service' command but know how to go into /etc/init.d and do it there.
This is what came off the top of my head and in no way should be used as a study guide or be considered a complete collection of everything an entry level Linux support tech should know.
PostPosted: Wed Jul 22, 2009 4:37 am
cd -
PostPosted: Wed Jul 22, 2009 6:03 am
TravBv2.0
TravBv2.0
Lodis, I definitely appreciate the advice, but this has nothing to do with my recent job interview invitation. I'm looking for blog articles to go between "I just learned the terminal basics" and "Now I'm learning how to manage Linux servers." Things that aren't very admin-type tasks, but the kind of things an advanced user might know.
(I'll keep what you wrote for some google and wiki reading later today though! :) )
PostPosted: Wed Jul 22, 2009 6:09 am
lulz, for some reason I read the last line and thought you were following up on your recent job application. brain fart...
PostPosted: Wed Jul 22, 2009 6:31 am
CrashTECH wrote:
furball146 wrote:
I'd hit it.
Given that her blog uses her sexuality VERY prominently to attract an audience, I think this is likely. I'm impressed, actually.
Also, yeah .. I'd tap that like a keg on Friday night.
PostPosted: Wed Jul 22, 2009 6:39 am
I can't read it at work... stupid proxy blocks it as "games".
/sigh
PostPosted: Wed Sep 09, 2009 2:12 pm
Spam Overload
Spam Overload
You should include some info on samba and swat. That's if swat is still the default samba management tool, it's been a while since I've used it so I'm not sure.
Setting up Samba shares should be pretty high up there on the to do list for linux geeks who probably have other Windows/Mac machines in the house.
