It is currently Fri Mar 06, 2015 8:30 am
 Post subject: How do you know if you are ready for an internship?
PostPosted: Sun Jul 19, 2009 6:55 pm
How much knowledge do you think is needed to get hired as an intern for programming. What are the basic task/functions are a must?
PostPosted: Mon Jul 20, 2009 3:32 am
Too broad of a question. It really depends on the company. For the most part you don't have to do too much of anything special because the internships are part of a school program so your classes are your prep work. Then future internships are also supported by your previous ones.
It is difficult if not impossible to tell you how to prepare without knowing where you are going and/or what the intern position entails.
 Post subject: Re: How do you know if you are ready for an internship?
PostPosted: Mon Jul 20, 2009 11:20 am
Minimum knowledge required: job description.
PostPosted: Mon Jul 20, 2009 11:54 am
It really depends on the company. A lot of times, the most they can get without having to pay you/pay full salary. Other times, it doesn't matter since you are supposed to be learning through the internship.
