It is currently Fri Mar 27, 2015 12:40 am
 Post subject: Posting Bug
PostPosted: Mon Jul 20, 2009 6:16 am
Has anyone encounter this before where if you post or preview a post in the forums, its blank? Apparently the message is too long or something as if I remove bits of the message at a time I can then preview it and it will show up. However if the full message is placed back then it disappears even with the message still in the text box.
I am running Vista x64 and this has happened to me in both Firefox 3.51 and IE 8.
PostPosted: Mon Jul 20, 2009 6:17 am
If you post a URL don't put the [ url ] tags around it, it makes the post go blank. Thats what kept doing it to me a while back..
PostPosted: Mon Jul 20, 2009 6:23 am
Million Club 5+ [PC]*
you can post links by themselves with no problem
it's when you start a tag and don't finish it that the post goes blank
PostPosted: Mon Jul 20, 2009 6:25 am
I said that.
Probably, but my example is when using the tags at all, not messing them up.
PostPosted: Mon Jul 20, 2009 7:36 am
Defiant wrote:
I said that.
ah never mind I misread your post
PostPosted: Mon Jul 20, 2009 2:55 pm
Ahh I see, thanks for all the help. :D :D
