It is currently Sun Apr 26, 2015 8:53 pm
 Post subject: websites to BLOCK
PostPosted: Tue Jul 07, 2009 7:46 pm
[size=18]what are some dangerous and inappropriate websites to definitely (note that it is spelled correctly) block? incase someone using the pc ends up on that site it wont go to the site. I already have a site blocker i added a few sites but i dont know much other ones to add to the list[/size]
PostPosted: Thu Jul 09, 2009 12:15 pm
it would be impossible to list all of those type of sites. One man's pr0n is another man's treasure.
PostPosted: Thu Jul 09, 2009 12:45 pm
pr0n >= treasure ?!!?
PostPosted: Thu Jul 09, 2009 10:47 pm
Monkey Fed [PC]
Monkey Fed [PC]
I would suggest you start with OpenDNS, and maybe add in some default websites and keywords. Hackman2007 can probably tell you more about this.
I agree with Queen. Inappropriate to you may mean something totally different to us. Specifics would be good.
PostPosted: Fri Jul 10, 2009 6:22 am
Funny, right under this post, it is partially addressed.
http://www.maximumpc.com/forums/viewtopic.php?t=95371
