It is currently Fri Jan 30, 2015 8:11 pm
 Post subject: Ok, i want to start, but im broke
PostPosted: Tue Jun 23, 2009 8:18 pm
Ok, i didnt want to have to scour these threads just to find an answer that doesnt fit me. I want to learn how to program, i want to bulid little programs that will run on Windows and maybe learn how toi make some lunix programs if i could. the issue is i have NO money to spend on this, so i am asking you guys if there is a way i can learn how to program (i prefer to learn C or C++) that wont cost me ANY money! Thanks guys, and if you need to, send me some info at timmersoft@live.com, thanks guys!!
John Boy
PostPosted: Wed Jun 24, 2009 3:15 am
http://tinyurl.com/nwulws
IDEs
http://www.microsoft.com/exPress/
http://www.codeblocks.org/
Without asking something more specific you are on your own. We have a thread stickied for how to get started and you basically told us you were too lazy to read it. Learning to program is learning to program.
http://www.maximumpc.com/forums/viewtopic.php?t=23833
BTW... http://tinyurl.com/cctpty
PostPosted: Mon Jun 29, 2009 2:56 pm
There are loads of free IDE's. I would check out Visual Studio C# Express, and its C++ counterpart. Those will suffice for your needs.
PostPosted: Tue Jun 30, 2009 4:40 am
Was the 'Where to start' thread that is stickied at the top of this folder not helpful enough? What information do you need that you didn't find in there?
PostPosted: Tue Jul 21, 2009 7:46 pm
I agree with the previous post. C# Express 2008 is likely a good fit. It provides a drag & drop form-building interface. There is a bit of a learning curve in writing the code in response to use inputs (double-click a given control for the default behavior), but there are a lot of tutorials for C# online. Simply choose an application you want to create, look for a tutorial that matches that. Likely you will hit on something.
C# exhibits features similar to those found in C++ (out parameters, for instance), is modeled after Java in that it runs in a virtual environment, the Common Language Runtime, and like both in that it' libraries contain pre-built data structures such as generic type lists and maps.
Concentrate on understanding the fundamentals at first; what are variables for, how does a routine (method, function, operation) operate on data to produce a given result (look up selection, iteration, sequence). Later, classes (and the objects that are instantiated from them) should be examined, since the majority of C# functionality is housed in them.
Editorial note: learning C++ to create Windows applications is a difficult task. The Microsoft Windows API was originally a set (a huge set) of C functions, later wrapped into C++ classes, but still with the difficult to understand API lurking underneath. C# offers many advantages such as resilience against memory leaks (the garbage collector nabs orphaned objects eventually), a robust interface and excellent debugging tools. Good luck
