It is currently Wed Apr 01, 2015 7:15 am
 Post subject: What do you think of my cable management (Oversize pics)
PostPosted: Sat Jun 27, 2009 10:26 pm
I am using an Antec 300.
http://i117.photobucket.com/albums/o53/ ... 530609.jpg
http://i117.photobucket.com/albums/o53/ ... 530620.jpg
http://i117.photobucket.com/albums/o53/ ... 530629.jpg
http://i117.photobucket.com/albums/o53/ ... 530643.jpg
http://i117.photobucket.com/albums/o53/ ... 530653.jpg
http://i117.photobucket.com/albums/o53/ ... 530655.jpg
http://i117.photobucket.com/albums/o53/ ... 530661.jpg
http://i117.photobucket.com/albums/o53/ ... 530664.jpg
Is there anything else I could do? I want MOAR!
Mod edit: Don't post images this big again. If it breaks tables on my 22" widescreen it is WAY too big. Not only that but it is obnoxious to download them. Do you have a specific question? A lot of the pictures don't show anything relevant to the thread title.
PostPosted: Sun Jun 28, 2009 4:23 am
Million Club - 20 Plus
:D
PostPosted: Sun Jun 28, 2009 6:31 am
Damn man! that's some kickass cable management! did you paint your case? i think im going to do that to my Antec 300.... one day...
can you post a pic that shows the entire case? thanks!
well done!
PostPosted: Sun Jun 28, 2009 12:15 pm
Sure. But they are from earlier before I put my better-er cable management in.
Actually go here and you can see more pics. :D
http://www.overclock.net/case-mods-gene ... gress.html
I will be repainting it (it looks crappy-ish) later this summer and will also be doing a new side panel (it will be a surprise)
PostPosted: Sun Jun 28, 2009 6:08 pm
dude, i wanna see more pics of this badboy. I own a 300, and my girlfriend has one (its on my desk right now for repairs) And i have to say that the Antec 300 is by far my favorite case on the bloody planet. MaxPc gave it a bad review (5/10 if i recall correctly) but i dont think that they took the fact that it was 50 bucks into consideration. my favorite server is in a 300 (ASRock mobo w/DDR/DDR2, AGP-PCI-e, Celeron E1200 1.6ghz and 2Gb of Corsair valu-ram) the whole thing cost me under 200 bucks (i payed 7.99 for each stick of ram (its got two 1gb dimms)
sorry, i just can't believe how good that machine has been...
ANYWHO! yes, i'd love to see more pics. that is such a great looking computer, please tell me what is in there!
By the way, that is a lovely case mod. did you cut the stock panel to drop in that piece of plexi?
PostPosted: Sun Jun 28, 2009 7:20 pm
Look at the links that I posted. You will see more <.<
Tell me what all you want to see.
Oh I forgot my system specs:
Antec 300 (7 fans <.< side view panel, and Cathodes)
Gigabyte GA-EP45-UD3R
e7300 @ 3.6 1.38125v (right now it is at 3.4 because it is too hot here right now)
Xigmatek s1283 w/ Ultra Kaze 3000RPM (taped) + IC7
OCZ Reaper 4GB DDR2 800 (1:1)
GTX260 656/1414/1175 (core,shader,mem)
Corsair TX650W
2 Seagate 250GB RAID0
1 WD Caviar Black 500GB (32MB)
Windows 7 RC1 & Ubuntu 9.04 (both 32bit)
It is my little beast. I love it :D Also it is the most power computer in my house lol
<.< My cables are the way they are after 5 revisions and my last mod was cutting my case with a dremel.
PostPosted: Sun Jun 28, 2009 7:29 pm
I say we should burn you as a witch. There aren't enough cables visible to run that.
PostPosted: Sun Jun 28, 2009 7:53 pm
Are they all shoved behind the motherboard?
PostPosted: Sun Jun 28, 2009 10:41 pm
I know your build is getting creamed over, but you asked...
Get a soldering iron and some soldering tools. No need for all that stuffed wiring. Trim it to fit. One picture, to me, told the story, and it's the 3rd one. Adapter, adapter, adapter...that's a build to me and should be average. Mod? Change something with your skills!
I think I could trim that backplane down to...2 runs? One Molex could more than likely run every single molex device you have in the case. One molex, could remove every single adapter in there, and that ugly back side would be wonderful to see in it's simplicity.
Adapters need axed in this section I'd hope. Should be the norm in Help Me Build...
I fail to see a mod.
PostPosted: Mon Jun 29, 2009 3:53 am
that thing must be SOOOO loud! 3k rpm fans?!! are you deaf now? haha
PostPosted: Mon Jun 29, 2009 9:28 am
Okay. I will look into it. Not all my fans can be put onto a single molex (because if I have to remove something or if I upgrade to a bigger case or something, then moving the fans would be a pain in the ass). As for my cables that cannot be seen, I did that on purpose but my camera sucks :/ so I cannot sow all the damn things. But if you look at the back of the mobo tray you can see the wires that are missing. And my PCI slot fans I solder those together onto a single 3 pin (from 2 molex e_e) and sleeved them.
As for how loud it is. Yes it is kind of loud but my GTX260 actually is louder than my 3k fan. The 3k is contolled by my board (and I use EasyTune 6 to adjust the fan speed based on temp). Most of the time my fan is running anywhere between 30-65%. But when I stress or if my processor gets above 55C it starts to go to 100%. My stock 140mm tri-cool is louder than most of my fans as well, but overall you her the are being moved through it <.<
