It is currently Wed Jan 28, 2015 3:13 pm
 Post subject: how to show CPU / Motherboard temperature on mandriva2009.1
PostPosted: Fri May 29, 2009 7:44 am
hey guys..
how to show CPU / Motherboard temperature on mandriva2009.1 ? Gnome edition.
Thanks !
PostPosted: Fri May 29, 2009 8:03 am
Motherboard type?
PostPosted: Fri May 29, 2009 8:44 am
Gnome Sensors should be able to do this.
I would think it's installable the same way on most distros running Gnome via a right mouse click on your panel (toolbar) and select add to panel...although I haven't ran Mandriva in a while to know for sure.
You could also look for desklets that do this at .gnome-look.org.
If you're running KDE, there should be similar methods there and you'd be looking at kde-look.org instead.
PostPosted: Fri May 29, 2009 12:09 pm
oh hi guys :) thanks for the reply :)
my motherboard is Asus p5kpl-cm.
i haven't really check into the gnome desklet yet and i've never really boot up mandriva to kde4 either.
At the moment I reboot and quickly hit <del> to check cpu/mobo temp: 62 degree C / 38 degree C respectively.
My biggest fear is how hot should CPU temp go up to; the cpu is Pentium Presler D945 (dual core) which are known for very high temp.
update:
after installing lm-sensors and running sensors-detect, i was able to see the "hardware sensor monitor" on the "add to panel" screen. However it shows "no sensors detected" once i've added it to the taskbar. Oh well :(
PostPosted: Fri Jun 12, 2009 7:05 pm
in terminal type sensors, if it gives you realistic voltages and temps use gkremll to display temps in side bar, goog;e gkremll for more info
PostPosted: Fri Jun 12, 2009 9:01 pm
WOW thank you so kindly sir !! it works !!
logicmaster@localhost ~]$ sensors
w83627dhg-isa-0290
Adapter: ISA adapter
VCore: +1.27 V (min = +0.00 V, max = +1.74 V)
in1: +11.93 V (min = +8.03 V, max = +3.38 V) ALARM
AVCC: +3.28 V (min = +0.91 V, max = +2.30 V) ALARM
3VCC: +3.28 V (min = +1.04 V, max = +0.00 V) ALARM
in4: +1.17 V (min = +1.02 V, max = +1.32 V)
in5: +1.62 V (min = +0.21 V, max = +1.80 V)
in6: +3.74 V (min = +2.10 V, max = +3.28 V) ALARM
VSB: +3.28 V (min = +0.02 V, max = +2.26 V) ALARM
VBAT: +3.28 V (min = +2.40 V, max = +2.43 V) ALARM
Case Fan: 2191 RPM (min = 37500 RPM, div = 4) ALARM
CPU Fan: 2445 RPM (min = 9121 RPM, div = 4) ALARM
Aux Fan: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan4: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan5: 0 RPM (min = 10546 RPM, div = 128) ALARM
Sys Temp: +39°C (high = +2°C, hyst = -118°C) [thermistor] ALARM
CPU Temp: +59.5°C (high = +80.0°C, hyst = +75.0°C) [CPU diode ]
AUX Temp: -58.5°C (high = +80.0°C, hyst = +75.0°C) [CPU diode ]
vid: +0.000 V
