It is currently Sun Apr 19, 2015 4:52 am
 Post subject: PHP error
PostPosted: Fri Jun 05, 2009 8:05 pm
Hey guys I am trying to teach myself php and I have no idea why I am getting
Parse error: syntax error, unexpected T_STRING, expecting ',' or ';' on line 6
<?php
session_start();
require_once('recaptchalib.php');
$publickey = "<I REMOVED THE KEY>";
if(isset($_SESSION[‘passCaptcha’]) && $_SESSION[‘passCaptcha’] == false){
echo ‘help me’;
These are the first eight lines of my file which are then followed by HTML.
I have also tried to use double quotes and that doesn't work either.
PostPosted: Mon Jun 08, 2009 5:44 am
Take a look at your if statement. After just quickly looking at it that is where I think the problem is.
You should have your compounded statements look something like this:
IF ((Condition1) && (Condition2))
    // Do Stuff
PostPosted: Mon Jun 08, 2009 11:44 am
CrashTECH,
Thanks for your help. However, I actually discovered my problem last night. If you will notice all of the single quotes, or what I thought to be single quotes were actually smart quotes (I think that's what they're called, it's the ones that on the key before the 1 key). I was using an editor called text wrangler on my mac and it has a feature that automatically uses these smart quotes instead of single quotes. Thanks for your help in this matter.
PostPosted: Mon Jun 08, 2009 12:19 pm
Yeah... I hate that. Just wait till you are translating data and it is littered with those.
PostPosted: Tue Jun 09, 2009 9:23 am
Super Mario Banhammer
Worse yet try parsing a *.csv file with embedded smart quotes and then forwarding it up to a mainframe and watch the mainframe job go ?? WHA? I Don't Understand You!! Dave? What are you doing Dave? KEEERRAAAASSSHHH
"Your perfectly good JCL Job Abended cause some shmo in"
"operations loaded the data file with embedded smart quotes instead of"
"embedded apostrophes"
"Batch Process Terminating" "Autopage for Sev1 Sent to Ops"
"Director for review." "Your Resume Auto posted to Monster.com"
"as a convenience to help you find your next employment station"
"Have a nice day :D "
:shock: :shock: :shock:
PostPosted: Tue Jun 09, 2009 9:31 am
:lol:
That was hilarious.
PostPosted: Mon Jun 15, 2009 7:13 am
:lol:
That was hilarious.
Glad to make your day Jip. But seriously, with the exception of the Monster.com part I have seen just such Abend messages in Batch especially around End Of Month.
BA's will use whatever tool they like to edit something some like notepad some like textpad some like Vi and all of them have differences in the way certain text characters are handled and they will dump raw text files embedded with the weirdest crap and then get all pissy when the job abends because they used a new editing or proofing tool.
