It is currently Fri Jan 30, 2015 7:52 am
 Post subject: Question/Advice
PostPosted: Thu Jun 04, 2009 4:22 am
I think I'm going to mod a HAF 922 with a nice side window and paintjob on the inside.
At this URL http://www.digitalstormonline.com/gamingcomputers.asp they show a HAF 932 with customized Red locking tabs for the optical drives.
Are these mods that can be bought? If not, what would it take to paint them a custom color? What type of paint would work well with that plastic type?
PostPosted: Thu Jun 04, 2009 6:38 am
Million Club [PC]
Million Club [PC]
thy can probably be bought from some store or other, maybe even from cooler master. as for modding the HAF, I wouldn't go too crazy, since its already a great case- a side window is about as far as I would take it. if they can't be bought, spray paint and masking tape will probably do the trick. :wink:
PostPosted: Thu Jun 04, 2009 7:58 am
Yea, mostly what I had planned was a side window and inside paint job. Nothing over the top.
