It is currently Mon Jan 26, 2015 11:11 am
 Post subject: Set aside disk space for Linux!
PostPosted: Mon Jun 01, 2009 6:10 pm
I am thinking of running Ubuntu Linux on the same hard drive my Windows XP is on. When I partitioned my hard drive for XP I made sure I didn't take the whole hard drive space. I set aside 40 to 50 GB of free disk space just for linux. I was wondering if Linux will see the unpartitioned disk space. Thank You.
PostPosted: Mon Jun 01, 2009 8:03 pm
Yes.
PostPosted: Tue Jun 02, 2009 6:37 am
During the install process, Linux will give you the option to use entire disk. Make sure you don't click on that! Otherwise you should be good to go.
PostPosted: Tue Jun 02, 2009 9:15 am
TravBv2.0
TravBv2.0
furball146 wrote:
Yes.
+1
