It is currently Sun Apr 19, 2015 5:09 am
 Post subject: controlling 7900GS fan speed
PostPosted: Thu May 28, 2009 9:05 pm
The fan on my 7900GS has a strange behavior: every 20 something seconds its will very briefly pause and then go back to its usual speed (30% I think).
I tried using nvclock to change the fan speed, but it doesn't stay. The fan will still do the pause and then it goes back to 30%.
How do I get it to spin constantly?
Im on Ubuntu 9.04 btw.
PostPosted: Fri May 29, 2009 12:16 am
TravBv2.0
TravBv2.0
Have you tried different drivers? How does it fare in Windows?
PostPosted: Fri May 29, 2009 4:54 am
Don't have Windows, but I will try different drivers.
PostPosted: Fri May 29, 2009 5:04 am
Aww nvm I found the problem. I was accidently running a script similar to:
http://ubuntuforums.org/showthread.php?t=828369
Apparently the 7900GS has two performance levels where the only difference is how fast the fan spins. Go figure.
