It is currently Wed Jun 19, 2013 11:03 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Mar 16, 2009 6:29 pm
Does that above code still not work?
And btw, I got that "march of progress" thing off of Cay Horstmann's website. You may not be familiar with him, but if you are taking an AP Computer Science course, you will be familiar with his work by the end of the year. You see, Mr. Horstmann had the honor of implementing the AP CS "GridWorld" case study. You will either love it or hate it. Here's hoping you'll love it, 'cause I hated it :(
PostPosted: Tue Mar 17, 2009 1:35 am
Oh it works, but I feel like it's the least efficient manner possible.
PostPosted: Tue Mar 17, 2009 6:18 am
Well for what you're doing, efficiency shouldn't really matter, as long as you're not doing something like
for(int i=0; i<1000000;i++) {}
//useful code...
PostPosted: Wed Mar 18, 2009 4:24 pm
Why that is true. Quert, can you look at my code I have and tell me where my test array is doing me wrong?
// Program By Dwood
// Version: 3.18.09
removed
If test[index] = zero then heatIndex[index] is supposed to equal temps[index]
I'm not getting that. Gah I hate this program D:
PostPosted: Wed Mar 18, 2009 5:12 pm
nevermind:
      for(index=0; index < 12;)
              if(temps[index] > 80) //notice the swap
                 test[index] = false; //notice the swap
             else if(humids[index] > 60)  //notice the swap
             else
                test[index] = true; //notice the swap
   if (test[index] = false)  //notice the swap
      < Heat Index Equation here >
      heatIndex[index] = heatindex;
      } // end of if statement
   else
         heatIndex[index] = temps[index];
   index++;
Something funky is amiss! Btw... initially when I reordered the original code that didn't help much :/ The changes only happened when I reversed the boolean operators.
<Program fixed!>
PostPosted: Wed Mar 18, 2009 5:19 pm
Once again, good job.
PostPosted: Wed Mar 18, 2009 5:24 pm
Actually... It turns out the output is now either ALL temps or ALL heatIndex... BAH!
PostPosted: Tue Mar 24, 2009 3:40 pm
OH man I hate this. All right so I have a circle whose radius can be anything as long as it is a relative of 1 (100, 10, 1, .01, .1 etc)
r^2 = x^2 + y^2 right?
Well I need to find the points on a circle given an increment of x, so x could be .90 (radius 1) so 1 = .81 + y^2
1 - x = .19
sqrt .19 = .44
I hate circles so much.
I just do.
PostPosted: Tue Mar 24, 2009 5:21 pm
Haaaaah Wow I'm retarded.
I forgot to use my Round method in the program.
Now it looks like things are perking up!
// Points On A Circle Version 1
// Dwood
// I have no idea what I am doing eh.
// Assume that the circle is at x = 1; y =1;
removed
Try that on for size. That's also how I should have made my other one look. Probably not the most robust program but eh I had fun. We'll see what happens.
PostPosted: Thu Apr 23, 2009 3:59 pm
most removed
public static double[] gravity( double mass[], double e[])
     return grav;
    public static void main(String[ ] args)
        double[]  grav = gravity(mass[], diameter[]); //What's the problem
I'm confused right now...
PostPosted: Thu Apr 23, 2009 7:51 pm
The problem is, array variable names are referenced the same way as normal variable names. So you would say:
double grav[] = gravity(mass, diameter);
PostPosted: Sun Apr 26, 2009 4:44 pm
here's a new one though.
[code]Removed
[code]
REMOVED [/code]
Grav[] turns out to be 0 no matter what. It's bugging me.
PostPosted: Sun Apr 26, 2009 7:42 pm
Try writing out 0.0000000000667 instead of 6.67E-11 .
PostPosted: Mon Apr 27, 2009 12:53 pm
Turns out that the for loop, less than operator in my gravity equation was really a greater than operation.
I have bolded it in my post to make it easier to find now.
PostPosted: Sun May 03, 2009 4:45 pm
      int decimalOwed = (int)((amtOwed - (int)amtOwed) * 100); //Intify for easier calculation
If I change decimalOwed to a double it's like 35.99994 or something...
Turns out I just need to add .5 and THEN cast it as an int.
Edited out most of the code because I'm submitting it in a bigger project.
PostPosted: Sun May 03, 2009 5:59 pm
Looks like you solved your own problem. Good job.
PostPosted: Mon May 04, 2009 2:06 pm
What bothers me is that amt owed is only 2 decimals back and multiplying 100 to it should therefore make the decimals 0. This is not the case. (in Java, anyways)
PostPosted: Thu May 14, 2009 3:14 pm
Sweet... So I'm onto REAL OOP.
:) This is interesting because I never thought of programming in Java this way... Looks like I still have a LONG ways to go :3 Eventually this course will be over and I'll be looking for more.
