It is currently Wed Apr 01, 2015 3:22 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jul 12, 2004 6:22 am
Found it.
http://www.a1-electronics.net/Heatsinks/2003/EverCool_WC-101_Apr03.shtml
The whole kit is crap IMO. But it does have that style waterblock.
PostPosted: Mon Jul 12, 2004 9:32 am
Good find! I was thinking of that one as well. There's still another feable attempt out there somewhere:p I'll run across it again soon I hope so I can post a pic as well...
 Post subject: heh
PostPosted: Tue Jul 13, 2004 7:35 pm
http://www.bigbruin.com/reviews/poseido ... arge/5.jpg
 Post subject: Re: heh
PostPosted: Wed Jul 14, 2004 3:47 am
Forbidden
You don't have permission to access /reviews/poseidonwcl03/large/5.jpg on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.31 Server at www.bigbruin.net Port 80
PostPosted: Wed Jul 14, 2004 3:49 am
Which is ok, because I seen the name of the kit in the link and found a review :)
http://www.ascully.com/modules.php?name ... ent&id=373
 Post subject: My bad for linking to an image
PostPosted: Wed Jul 14, 2004 2:35 pm
so I backed out the .jpg> http://www.bigbruin.net/reviews/poseidonwcl03/
 Post subject: Re: My bad for linking to an image
PostPosted: Thu Jul 15, 2004 3:40 am
Jima13 wrote:
I did that as well, but I wanted to find a place that would allow me to view a full size image of the kit.
PostPosted: Sat Jul 17, 2004 1:48 pm
i dont think it will work either, you will be using case temperature air to try and cool a block that is already cooler than the air being used to cool it. i use water on the cpu only, and the case temp is always 10 or more degrees higher that is with a 120 and an 80 in, and 2 80s out plus the dual fan 550 truepower, still is interesting concept. :)
PostPosted: Sat Jul 17, 2004 6:28 pm
uh...the water should be about the same temp as the air because it runs off air cooling also (radiator)
PostPosted: Mon Jul 19, 2004 1:18 pm
Yes, and no. If your radiator is positioned in a place that it gets a healthy supply of fresh air from outside the case, then it should make the water lower than the case ambient air that would be cooling the sinked waterblock. He isn't saying colder than room air, but rather colder than the case air and this is possible to do to an extent, especially if your Radiator is an external unit .
PostPosted: Mon Jul 19, 2004 1:19 pm
Sorry, some glitch caused me to double post.
PostPosted: Mon Jul 19, 2004 2:52 pm
Jima13 wrote:
Still not the POS I had seen. This one I seen was an actual HS/F with some water in it. Totally weird thing it was. Maybe it was so shitty that they erased it from exsistance!?
PostPosted: Mon Jul 19, 2004 3:02 pm
This is something I've been toying with actually. I've always just had the radiator mounted on the inside the case on the dual fan outlets. Having it up front would draw the fresh air through the radiator, but exhaust the warm air right into the case. But the theory that the warmer air being used to cool the radiator like I do is pretty sound.
I just feel it's pretty realitive in some cases (pun intended). I have an OTES card so that air goes right outside. Then with the CPU being cooled by water, there's no HS/F to blow hot air around and it's actually being pushed right out the back of the case through the radiator. Then, the only other item in there that makes heat is the Mobo's power which again is handled with an Abit OTES config. This just leaves the harddrives and general convection of the parts to heat the guts of the case. So....the case is even cooler than a normally cooled box and, again, pretty realitive.
I've done nothing really scientific to confirm this, but I don't have any problems. Now, the OUTSIDE of the case is hot! I can't set here on hot days without running the A/C. This little corner I play in just gets freaking unbearible. If I post like a grumpy bastard in here, blame the heat!
