It is currently Sun Mar 01, 2015 9:30 pm
 Post subject: WINE problems... *sigh*
PostPosted: Fri Apr 24, 2009 9:09 pm
Million Club [PC]
Million Club [PC]
I run an ubuntu winXP dual-boot on my machine, though I only boot into WinXP to play games because I don't want to deal with WINE. When I updated to 9.04 though (which by the way is faster, shinier, better-supported, and all-around way better than the already excellent 8.10) I decided I would try getting the xfire chat client running, so I could keep in touch while I worked and all. well, I installed wine, xfire installed fine when using the XP API, Vista gave me errors, but after googling it, that's just a bug, not anything I'm doing. but anyways, after installing it I type into the command line the normal stuff:
wine "/home/spartacus/.wine/drive_c/Program Files/Xfire/Xfire.exe"
and then it seems to be starting fine, and gives me this:
fixme:win:WIN_CreateWindowEx Parent is HWND_MESSAGE
fixme:shdocvw:PersistStorage_InitNew (0x15f6f8)->(0x66bd84)
fixme:shdocvw:OleObject_Close (0x15f6f8)->(1)
fixme:shdocvw:PersistStorage_InitNew (0x127c0b8)->(0x66bd84)
fixme:shdocvw:navigate_url Unsupported args (Flags 0x32e31c:3; TargetFrameName (nil):-1)
fixme:urlmon:URLMonikerImpl_BindToObject use running object table
fixme:shdocvw:BindStatusCallback_OnProgress status code 11
fixme:shdocvw:BindStatusCallback_OnProgress status code 14
fixme:iphlpapi:NotifyAddrChange (Handle 0x7d2af9e8, overlapped 0x7d2af9cc): stub
fixme:system:SetProcessDPIAware stub!
fixme:msimtf:CActiveIMM_Create ((nil) {08c0e040-62d1-11d1-9326-0060b067b86e} 0x1cdef34)
fixme:ole:CoCreateInstance no instance created for interface {08c0e040-62d1-11d1-9326-0060b067b86e} of class {4955dd33-b159-11d0-8fcf-00aa006bcc59}, hres is 0x80004002
fixme:shdocvw:ClOleCommandTarget_QueryStatus (0x127c154)->((null) 1 0x32d6d8 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x127c154)->((null) 25 2 0x32d6ec (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x127c154)->((null) 26 2 0x32d6ec (nil))
fixme:urlmon:ObtainUserAgentString (0, 0x32d2a0, 0x32d29c): stub
fixme:mshtml:OleControl_OnAmbientPropertyChange not supported AMBIENT_USERAGENT
fixme:shdocvw:ClientSite_GetContainer (0x127c154)->(0x32d728)
fixme:shdocvw:ClOleCommandTarget_Exec (0x127c154)->({000214d1-0000-0000-c000-000000000046} 37 0 0x32d7fc (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x127c154)->({000214d1-0000-0000-c000-000000000046} 84 0 (nil) 0x32d88c)
fixme:shdocvw:PersistStorage_InitNew (0x1ecf0c8)->(0x66bd84)
fixme:shdocvw:navigate_url Unsupported args (Flags 0x32e9e0:3; TargetFrameName (nil):-1)
fixme:shdocvw:ClOleCommandTarget_QueryStatus (0x1ecf164)->((null) 1 0x32dd9c (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x1ecf164)->((null) 25 2 0x32ddb0 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x1ecf164)->((null) 26 2 0x32ddb0 (nil))
fixme:urlmon:ObtainUserAgentString (0, 0x32d964, 0x32d960): stub
fixme:shdocvw:ClientSite_GetContainer (0x1ecf164)->(0x32ddec)
fixme:shdocvw:ClOleCommandTarget_Exec (0x1ecf164)->({000214d1-0000-0000-c000-000000000046} 37 0 0x32dec0 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x1ecf164)->({000214d1-0000-0000-c000-000000000046} 84 0 (nil) 0x32df50)
fixme:mshtml:HTMLDocument3_recalc (0x1ed2118)->(ffffffff)
fixme:mshtml:HTMLElement2_get_clientWidth (0x1ecf908)->(0x32ea34)
fixme:mshtml:HTMLElement2_get_clientHeight (0x1ecf908)->(0x32ea34)
fixme:mshtml:HTMLElement2_get_clientWidth (0x1ecf908)->(0x32efd4)
fixme:mshtml:HTMLElement2_get_clientHeight (0x1ecf908)->(0x32efd4)
fixme:mshtml:HTMLElement2_get_clientWidth (0x1ecf908)->(0x32e7c0)
fixme:mshtml:HTMLElement2_get_clientHeight (0x1ecf908)->(0x32e7c0)
fixme:win:EnumDisplayDevicesW ((null),0,0x32ebd4,0x00000000), stub!
fixme:d3d:WineD3D_ChoosePixelFormat Add OpenGL context recreation support to Set
DepthStencilSurface
looks like it's going to work, but then it gives me this error and crashes:
err:d3d:WineD3D_ChoosePixelFormat Can't find a suitable iPixelFormat
fixme:d3d:WineD3D_ChoosePixelFormat Add OpenGL context recreation support to SetDepthStencilSurface
X Error of failed request: GLXBadDrawable
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 5 (X_GLXMakeCurrent)
Serial number of failed request: 3711
Current serial number in output stream: 3711
what gives? I seem to be doing it wrong, because other people have gotten it working... any ideas?
PostPosted: Fri Apr 24, 2009 9:38 pm
If it's Xfire you want, maybe Gfiremight work. I don't have Xfire, and I'm in Windows at the moment, so no clue if it does work, but googlecan help.
PostPosted: Fri Apr 24, 2009 9:40 pm
Looks more like an issue with OpenGL, although it's hard to tell if wine is the problem or OpenGL
Did you start new with 9.04 or just simply update what you had before and does glxinfo tell you anything telling? You might want to filter that command with "| grep direct" and | "grep OpenGL" The first will tell if if direct rendering is working and then other will tell you about OpenGL.
PostPosted: Sat Apr 25, 2009 6:54 am
Million Club [PC]
Million Club [PC]
I did a fresh install of 9.04, because my old disk drive was broken and crashed when I tried to update to the beta from alternate install disk, which broke some packages, so I decided to start fresh.
also, I'm assuming that Gfire is not compatible with xfire's servers, which is the point- the people I would want to chat with use xfire.
and yes, I tried using the google, couldn't find anything that wasn't a guide that tells you to do exactly what I did.
I'll try that OpenGL filtering and post results back.
PostPosted: Wed Jun 03, 2009 10:34 am
Do you have compiz or beryl enabled?
Gfire only requires a touch of tweaking now and then...
Quote:
Question: I cant connect, the server tells my that my xfire version is out of date
Answer : Xfire changes versions very fast and you always have to use the latest version.
Go in the account settings of you xfire account in gaim/pidgin and open the advanced configuration.
Up the version to the actual xfire version. When xfire is at version 1.89 this means you have to set your version to 89
