It is currently Thu May 23, 2013 7:31 pm
 Post subject: .NET Parallel framework
PostPosted: Fri Apr 24, 2009 10:21 am
Since I haven't been on these here forums, for goodness how long (due to school then working and traveling). I'm gonna try to be more active here, so in lieu of this:
http://msdn.microsoft.com/en-us/concurr ... fault.aspx
What do you guys think about the upcoming .NET 4.0 framework with ParallelFx?
For the newbies :) Parallelism is executing code in one or more processor cores. Parallelism differs from threading in that threading deals with executing different threads of work (execution code) where parallelism executes a portion of work amongst different processors.
Personally, I'm excited. .NET 4.0 is going to introduce a LOT of power to developers. However, it feels like I'm going to be spending time learning a new pattern for both threading AND parallelism.
If you guys are planning on using .NET 4.0, how do you intend on using it?
PostPosted: Fri Apr 24, 2009 10:49 am
We are still writing .NET 2.0 applications here :)
I need to try to keep up with it. A lot of business I think are "slower" to move to new frameworks.
PostPosted: Fri Apr 24, 2009 10:52 am
If I weren't developing for Sharepoint, I'd be on 3.5 right now. I'm using 3.5 on my pet projects. I was using .NET 3.5 and, let me tell you, LINQ will make your life easier.
I love LINQ:
var query = from t in table
                  orderby t.Createdate ascending
                  select t;
Beautiful man, beautiful.
PostPosted: Fri Apr 24, 2009 10:54 am
Haven't used LINQ. Not sure I am a fan of dropping that stuff right in the middle of my code.
PostPosted: Fri Apr 24, 2009 12:18 pm
Well, LINQ is an umbrella term. LINQ can be used for collections.
//return a subset of ints in the list
int[] myInt = new int[] { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 };
var anInt = myInt.Where(x => x >= 2 && x <= 9);
List<int> listOfInts = anInt.ToList();
//return the first element in the list
var anInt = myInt.Where(x => x >= 2 && x <= 9).FirstOrDefault();
int thisInt = anInt;
It makes finding things inside collections (anything that implements IEnumerable and IQueryable) easier. The examples above do no justice but a good primer on it.
Highly recommended. I use LINQ pretty much exclusively now, it makes writing a Data Access Layer easier and if you use LINQ to SQL, it will generate business objects for you. :)
