It is currently Thu Mar 05, 2015 2:42 am
 Post subject: ZoneAlarm + IIS problem
PostPosted: Tue Jul 13, 2004 11:16 am
Hello,
Has anyone experienced problems with IIS when ZoneAlarm is installed? Here is what happened:
My computer runs Windows XP Pro with free ZoneAlarm. Just the other day after a trip, i wanted to setup the web server using IIS so my friends will be able to see the pictures i took.
Being lazy, I didn't want to write any HTML pages, so I enabled browsing for the directory in which the picture files reside. I was able to browse all the way into the directory; however I could not open the picture files.
the IP of my computer is 192.168.0.100; however, my router box has virtual server capability. I have it setup so for HTTP requests, it will forward them to the computer. In addition, I have enabled allow access and allow server for both trusted zone and internet in ZoneAlarm.
Later on, I discovered that the pictures would load if I use http://192.168.0.100/pics/pic1.jpg. But if I use the IP of the router, I was only able to browse to the pics directory, but could not open any jpeg files.
After uninstalling zoneAlarm, everything worked fine. I just feel uneasy about not running ZoneAlarm...
has anyone experienced this kind of problems? And has anyone found a way to solve it? Thanks!
 Post subject: Re: ZoneAlarm + IIS problem
PostPosted: Tue Jul 13, 2004 1:35 pm
emanresu wrote:
Hello,
This is a rather useful site for ZoneAlarm and its uses: http://www.markusjansson.net/eza.html
Did you try and play around with the file permissions?
PostPosted: Tue Jul 13, 2004 11:11 pm
It sounds like you need to set up your trusted zones a little bit more to handle the requests.
You might also try a different firewall app (Sygate or Kerio are good and I think they both have free versions/free home use) that are (considerably) more configurable.
PostPosted: Wed Jul 14, 2004 6:35 am
emanresu,
Post a copy of your ZoneAlarm logs for the relevant connection attempts. Once we know what it's blocking, we can figure it out how to allow it.
PostPosted: Wed Jul 14, 2004 7:32 am
well, I did set up a trusted zone range from 192.168.0.0 - 192.168.0.255, which should have convered both the router and the computer.
Right now, I have uninstalled zoneAlarm. I will do what [ch]amsalot suggested and post a log here... however, it won't be until tomorrow. some stupid thunder storm struck last night and my apartment was out of power. Not sure when they will fix it.
I will try to stick with zoneAlarm... swtich to sygate or kerio only if zonealarm is hopeless.
thank you for your help.
PostPosted: Wed Jul 14, 2004 8:03 am
The router is passing your friend's IP, which is probably still in the Internet Zone.
