It is currently Sat Mar 28, 2015 5:44 pm
 Post subject: Kalyway Leopard 10.5.2 Help Please
PostPosted: Fri Mar 27, 2009 4:56 pm
I have tried this on 3 computers. 1 was running Vista and the other 2 were running XP. When I try to boot from the CD on XP it starts loading then then my computer reboots and then if I try it again it reboots and it keeps rebooting. On vista when I try to boot from the CD while it is loading I get an error saying "ERROR: FireWire unable to determine security-mode" and it doesn't do anything.
Thanks
PostPosted: Fri Mar 27, 2009 4:58 pm
Monkey Fed [PC]
Monkey Fed [PC]
What CD are you trying to load? Are you using an external Firewire CD drive to boot from?
PostPosted: Fri Mar 27, 2009 5:00 pm
no i am using a normal DVD drive and I am loading a cd with a patched version of leopard
PostPosted: Fri Mar 27, 2009 5:09 pm
Monkey Fed [PC]
Monkey Fed [PC]
Erm, patched version of Leopard? As in "special" torrent download of Leopard? If this is the case, we can't help you out with hacked/patched OS's.
PostPosted: Fri Mar 27, 2009 5:50 pm
iron colbinator
iron colbinator
I don't really know much about osx86, so it'd all be googling.
http://lifehacker.com/348653/install-os ... -required/
It's illegal if you don't have a valid Leopard license, of course, but that's kind of out of scope for the actual install, I guess.
PostPosted: Fri Mar 27, 2009 6:36 pm
thank you
PostPosted: Sat Mar 28, 2009 5:07 am
Also, your hardware has to be compatible .. and it is a short list of hardware that Apple works with.
Try the Insanely Mac forums as well .. they've got lots of info posted about running OSX on non-apple hardware.
PostPosted: Sun Mar 29, 2009 6:17 pm
What you need to understand is that your machine is kernel panicking !!
Press F8 before Apple logo screen appears, you will see a boot prompt. type -v and press enter. THis is verbose mode. -x is safe mode, try that next...if you can't make sense of what the kernel panic is...which I assume you can't (no offense meant it's fairly cryptic to someone that doesn't know a thing about UNIX).
Other boot options include...:
-Platform="X86PC"
-Platform="ACPI"
-Platform="cpu 1" IIRC shh look it up in case ;).
PostPosted: Mon Mar 30, 2009 4:13 am
It is possible that the OP patched his own disc and that it was a purchased disc. We will just assume this is the case :)
The whole thing is a pretty gray area but is generally "accepted" as okay as long as you own the/an OS license.
