It is currently Wed May 06, 2015 9:55 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 12, 2009 2:54 pm
Monkey Fed [PC]
Monkey Fed [PC]
That is just weird. Adding the drive as a slave and jumpered properly shouldn't have eaten the MFT like that. With this new information, I'm beginning to think it may not be that adapter, but something else in your PC. Did you have the drive properly recognized in the BIOS before you booted?
PostPosted: Thu Mar 12, 2009 3:25 pm
Sorry if that was relevant information.
This is exactly what I did. My two CD drives are on the IDE channel, and I pulled the slave and added the drive. During the normal boot, the HDD showed up with the master CD and I continued to the splash screen. I never made it to the GUI before the BSOD and reboot.
I bought the adapter that night and tried it on a couple of drives I wanted to check (worked great), and then tried it on the other drive.
PostPosted: Thu Mar 12, 2009 3:29 pm
Monkey Fed [PC]
Monkey Fed [PC]
Tell ya what....why don't you make a post in the Free Clinic about this issue with the HD's and see what some other folks have to say. I'm not an expert with HD's and MFT's, but something does sound screwy. I just can't believe it was all coincidence. Also, I would link back to this post so they can look at some history.
PostPosted: Thu Mar 12, 2009 3:54 pm
Done, click here for the continuation
PostPosted: Thu Mar 12, 2009 4:06 pm
Monkey Fed [PC]
Monkey Fed [PC]
Awesome! You'll get a lot more feedback in there, for sure.
PostPosted: Thu Mar 12, 2009 6:56 pm
Ya, check again. We don't deal with KNOPPIX in there, nor do we fix macs.
Back to the drawing board.
PostPosted: Thu Mar 12, 2009 7:01 pm
Monkey Fed [PC]
Monkey Fed [PC]
Fack, my bad. I thought he was just using Knoppix to recover his software and info.
EDIT: So wait a minute, if you're using Chkdsk, and it's NTFS, and you're also using BartPE, was this a Linux or Windows install you're trying to recover?
PostPosted: Thu Mar 12, 2009 7:24 pm
No, no...
The Linux was just to try and recover file brought on by a Windows problem.
That is why I moved the discussion to the Free Clinic.
No Linux issues, so this thread has served it's purpose.
Sorry if that was not clear.
PostPosted: Thu Mar 12, 2009 7:38 pm
Yea..I was a little unclear as to why post in here since the linux part was only dealing with mounting the drive and the main issue was cluster repair.
PostPosted: Thu Mar 12, 2009 7:41 pm
Monkey Fed [PC]
Monkey Fed [PC]
Never fear! There's a post in the FC for this now lol. Confused the hell out of me for a minute too! :lol:
PostPosted: Thu Mar 12, 2009 8:02 pm
That is because I am noob here, and was not sure what sub was best. :lol:
PostPosted: Sat Mar 14, 2009 10:04 am
CrashTECH wrote:
Ayrton wrote:
Running GetDataBack now... :cry:
How did it work for you? I have used it on at least two occasions with failed drives and gotten back at least 97% of everything on the drive.
I wanted to follow up on this, and to add that GDB recovered all 358gb of data, and none of it looks to be compromised.
The scan took a full 48 hours, but it did recover all of it.
