It is currently Sat Apr 18, 2015 8:48 am
 Post subject: replacing proc in HP6835
PostPosted: Mon Jul 12, 2004 4:43 pm
my friend has hp pavillon 6835 and wants a new proc in it...it is a P3 socket 370 w/ a 100mhz FSB...they say it can support up to a 1gig P3, but it is cheaper to buy a P3 1.13g w/ 133FSB...i assume the 1.13 will be able to run at 1gig w/ 100FSB, but i have never tried it before...am i correct or do i just need to pay more for the 1gig proc? thanxs!
 Post subject: Re: replacing proc in HP6835
PostPosted: Mon Jul 12, 2004 6:23 pm
Folding Master (Top-ranked)
Check the hp site and see if there are any bois upgrades and what they bring with them. I do not beleive your motherboard will support a 133 fsb cpu.
PostPosted: Mon Jul 12, 2004 7:01 pm
well, the only processors i have any experience with is amd's...and i know u can run them at slower speeds no problem (like at a 100fsb instead of 133), i assume Intel's P3s would be the same, but i have never delt with them before so i thought i would check first...
PostPosted: Mon Jul 12, 2004 10:42 pm
you might be able to call HP and ask
PostPosted: Tue Jul 13, 2004 12:39 am
Chief Surgeon
Chief Surgeon
Xardion,
The fastest 100FSB Processor you could put into that would be the Celeron 1.4GHz. This was the final speed bin for S370.
Newegg's got 1.3's in stock:
http://www.newegg.com/app/viewproductdesc.asp?description=19-112-161&DEPA=0
Note: These "Celerons" (1.0GHz and higher) all have 256k onboard L2 Cache. So for all intent and purposes, they are P-III's.
SC64
PostPosted: Tue Jul 13, 2004 1:33 am
Think about what happens when you run a lower bus speed with the same multiplier.
[img]http://www.snackbar-games.com/folding/Phred15.jpg[/img
PostPosted: Tue Jul 13, 2004 6:02 am
thanxs for the help, i ended up ordering this proc from zipzoomfly...i will let u know if it worked :)
PostPosted: Tue Jul 13, 2004 12:43 pm
you're going to need an adapter to use a tualatin celeron 1.2MHz on that motherboard(i810)
http://www.upgradeware.com/english/prod ... /370gu.htm
http://www.powerleap.com/PL-370T.html
