It is currently Fri Jan 30, 2015 9:08 pm
Post new topic Reply to topic  [ 591 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 30  Next
PostPosted: Thu Nov 04, 2004 4:04 pm
Have you been banned before?
Guess I should post my OC efforts: 1800+ tbredB at 1.8ghz on a 334 mhz fsb
 Post subject: Old School P4
PostPosted: Fri Nov 05, 2004 4:11 am
I'm still running a 533 P4 2.4 but here is the important stuff
Gigabyte 8PE667 Ultra 2
2.4Ghz P4 @ 2.88
1GB Samsung pc2700 @ 400Mhz
2 WD 80GB HDD raid 0
Radeon 9700 pro 355/340
Lite-On 52x24x52 cd-rw
Lite-On 16x DVD-rom
Enlight 420W PS
2x NEC FE991sb 19" monitors
 Post subject: Re: Old School P4
PostPosted: Fri Nov 05, 2004 12:06 pm
Whoa, is this the same RamRod from Delphi? Haven't seen you in a while. Welcome. :)
***edit***
Just checked your profile... Looks to be the same. How have you been?
Farva: "Say car RamRod". :lol:
 Post subject: Re: CPU speed brag time!
PostPosted: Sun Nov 07, 2004 6:24 pm
Million Club 2+ [PC]
Dexter wrote:
All right all your overclockers lets see how much you've managed to crank up the speeds on your procs!
Well I'm an old fart in the land of computers. I'm still running the same p3-450 I built back in the summer of 99!
I have it cranked up to a whooping 504mhz!
Funny thing is my system still does everything I need it to do. Email, chat, multimedia(mp3, dvd, etc), software development, web development, basic office junk, etc. Heck I even run a FreeBSD (4.10) server inside vmware on my machine for my web development.
You can view my computer here: http://www.alanbarber.org/my_computer.php
Dual 1.26 P3T at 1.4
P4C 2.4@3.3
Pentium 166@225
PostPosted: Thu Nov 18, 2004 11:18 pm
I had an awsome rig a little while ago, but It was stollen... :(
I've been running a p3 733 with radeon 7500 and a p3 933 dual server with only one chip. But this is what I had...
Asus A7N8X - Dx (rev 1.4 even!)
1700+b @ 2.33
2 x 160G WD SE
2 x 80G SATA In raid 0
Radeon 8500 A-I-W
Now I'm waiting on my DFI LANparty UT 250GB and A64 3200+ to come in! let the fun begin again!!! Only problem is I'm stuck with a 7500 A-I-W for now :oops:
PostPosted: Fri Nov 19, 2004 12:18 am
p3 950Mhz>1102Mhz
PostPosted: Wed Dec 08, 2004 6:57 pm
i had a question, if u buy say pc3700 ram (466 mhz) w/timing 2.5-3-3-8 would the timings go lower if i ran it at normal pc3200 (400mhz)?
mabey ill buysome and overclock down the road
PostPosted: Wed Dec 08, 2004 7:53 pm
Contributing Writer
Contributing Writer
It really depends on the specific make/model. Your best bet, however, is to pick up one the dimms using the Samsung TCCDs. They're very high quality PC3200 sticks running at 2-2-2-5, yet they have a lot of overclocking headroom if you loosen the timings. It gets no better than these:
Kingston HyperX UL - $274
OCZ Platinum Revision 2 - $270
Mushkin Hi-Perf Level II - $252
Corsair XMS XL - $251
Patriot XBL - $224
PostPosted: Thu Dec 09, 2004 4:13 am
[url=http://www.newegg.com/app/ViewProductDesc.asp?description=20-220-033&depa=1]Patriot
XBL[/url] - $224
im kinda wondering tho, is it worth it for the best 2-2-2-5 settings if when u start overclocking ur gona start loosening the timings u get much slower ones if u do anything serious in terms of oc/ing,
iwas thinking, u got the pc3700, thoes timings arent at the ground floor but there not that bad, (OCZ ram btw) u could have them timings at a much higher fsb than say the pc3200 as you mentioned above (forgive me tho the entire idea of overclocking is new to me thanks to OEM)
PostPosted: Thu Dec 09, 2004 7:32 am
Contributing Writer
Contributing Writer
Good question. Depends on why you assume the PC3700 would hold their higher latencies at a "much higher fsb than" the TCCD based dimms?
Memory Roundup - notice how the TCCD stacks up against the PC4800
OCZ Review - notice the timings at 250, which is DDR500/PC4000 (2.5-3-3-7). That's tighter than the slower clocked PC3700 questioned above.
The Samsung TCCDs will run extremely tight at stock, yet has the same headroom as PC4000+. Simply put, it gets no better than these sticks right now.
PostPosted: Thu Dec 09, 2004 10:38 pm
well this is still making me undeciced, exept possably PDP if i go pc3200 or ocz if i go up from there
PostPosted: Thu Dec 09, 2004 10:44 pm
Contributing Writer
Contributing Writer
In all reality, there's little difference (besides price) in those TCCDs listed above. I'm partial to OCZ because of their customer service, but it comes at a price.
PostPosted: Thu Dec 16, 2004 2:31 pm
What about the crucial ballistix I hear so much about? I know they are Micron, not the Samsungs. They seem to be competitive.
PostPosted: Thu Dec 16, 2004 2:35 pm
Contributing Writer
Contributing Writer
I can't say anything bad about Crucial Ballistix, nor can I say that Samsung TCCD's are the only game in town. There are very worthy alternatives, Ballistix being one of them.
PostPosted: Fri Dec 17, 2004 3:58 pm
I just got my A64 939 3200+ 2.0 up to 2.6GHz. Thats FX-55 speed (minus 512KB cache...)!!!
in superpi, i'm down to 35s for 1M
PostPosted: Sat Dec 18, 2004 5:55 pm
i have 2.6 northwood at 3.4 stable and at very low temps. i dont know the temps off the top my head but i think theyre quite low.
PostPosted: Wed Dec 29, 2004 7:22 pm
P1 233mhz to 333mhz stable only under windows XP
-Actually used a thermaltake 6cu heat sync and strapped an 80mm fan on that
P2 400mhz to 450mhz somewhat stable....
-used a heat sync about 2 and 1/2" high and as wide as the chip, rigged an amd heat sync fan and a cooler master (6000rpm) fan to it and let it rip, could run call of duty just fine, warcraft 3, battlefield 1942 as well. It could run need for speed underground2 (pretty laggy) and battlefield vietnam. I never managed to get to putting doom3 on it though...
All my overclocking has been done with the jumpers.. so im really new to this overclocking through the bios.
 Post subject: hows this for power 4.00ghz CPU
PostPosted: Thu Dec 30, 2004 6:41 pm
3 Gbs of RAM, Intel’s newest Mob and 3.05Ghz CPU, and to top it all off everything in the tower is water cooled, which allowed me to overclock the snot out of it to a grand total of 4.00Ghz. :D
PostPosted: Thu Dec 30, 2004 7:03 pm
That is awsome, i just got a p4 3.0, bit 512mb of ram... i dont think i can push that very far :D
 Post subject: Re: hows this for power 4.00ghz CPU
PostPosted: Thu Jan 20, 2005 4:02 pm
no Intel processor @ stock speeds runs at 3.05 Ghz and I highly doubt that any Intel would take a 995 mhz increase
3 gigs of ram?
how about some pics
you only need one account nightfire007
