It is currently Mon Jan 26, 2015 2:43 pm
 Post subject: Changing your password
PostPosted: Thu Mar 29, 2007 12:55 pm
Maximum PC Editor
Maximum PC Editor
To change your password:
Via the forums.
Once logged in, go to profile link.
Click on the “profile informationâ€
PostPosted: Thu Mar 29, 2007 1:01 pm
Monkey Federation (Top 10)*
Guess it is fixed!
PostPosted: Tue Apr 03, 2007 6:41 am
Works here
PostPosted: Tue Apr 03, 2007 8:11 am
Works GREAT!!!!
Thank you :!: :!:
PostPosted: Wed Sep 17, 2008 10:11 am
There's something wrong with the password function on the forums. I go to maximumpc.com and try to login with the username and password I KNOW that I have. But it rejects it. So everytime I have to click on Forgot Password so a new password is sent to me. Then I have to modify the password. This has happened to me like 15 times already in the last few months so there's something definitely wrong with the script.
PostPosted: Wed Sep 17, 2008 10:41 am
That happened to me on another website and it finally got to the point where I stopped going there because if it.
I feel your pain.
PostPosted: Sat Oct 25, 2008 6:21 am
I had the same problem. It's an easy fix though, just delete your cookies for maximumpc.com is worked for me.
 Post subject: password
PostPosted: Mon Mar 02, 2009 7:39 pm
Everytime i try to log in -rejected- have to use lost password,. not going to keep doing that, No edit feature or change password, maybe that's the way it's supposed to be-- oh no-- first site i have ever had an issue with, no email responses or notifications, sorry, good bye good luck, i tried , know when i'm not wanted
:o
PostPosted: Mon Mar 02, 2009 9:25 pm
Monkey Fed [PC]
Monkey Fed [PC]
Did you ever PM an admin or delete your cookies and try again? Do you have cookies set to be saved on your machine?
PostPosted: Mon Mar 02, 2009 10:11 pm
Yes i did,,,Yes i do .
logged in this time but the profile shows no way to change pw
got a notify also on your post
PostPosted: Mon Mar 02, 2009 10:45 pm
Another path:
1. Click the "MAXIMUMPC" logo which is currently at the top left corner. This will take you from the forum section to the magazine homepage.
2. Click "Edit Your Account" directly below "Welcome <your username>" at the top of the page.
3. You should land on an "Edit" form that will allow you to update your account settings.
 Post subject: pw
PostPosted: Mon Mar 02, 2009 11:33 pm
thanks for the tour, i think i'd rather build a pc than navigate this site,
somebody must have been hitting the keys the same time i was?
:) :wink:
now if i can get to some issues in a few days wore out for now,.
 Post subject: Re: Changing your password
PostPosted: Thu Mar 28, 2013 8:45 pm
Thanks. I've got to change my password for security reason. So, thanks for that mate :)
