i tried using windows files/setting transfer wizard found in the acc/sys tools/ and had my settings and files sent over to another computer on my network
the initial plan was to reinstall windows as the computer became unstable
i reloaded xp and now i can't get the files back onto the computer it says not enough disk space but there was <4 gigs of data
so i tried running the file/setting wizard on another computer and transfer the files there but i get the same msg.
the files are several years worth of pic/music/word docs so i really need to have access to them
is there a third party app that will let me extract the file manually like a zip folder
the file type extension is *.dat
its in a folder called usmt2.unc and the files in the folder are img00001.dat and img00002.dat and a status file
i really want my files
