It is currently Fri Mar 06, 2015 4:16 pm
 Post subject: AMD Cool N Quiet (or PowerNow)...
PostPosted: Tue Sep 02, 2008 11:36 pm
Team Dino
Team Dino
I bought a HP DV5-1003NR recently.
It has a Turion X2 RM-70 (2 GHz), and it's running Vista SP1.
Does anyone know of a way outside of the BIOS to disable AMD's CPU throttling?
Chat with HP was no help.
Looking around the web I haven't been able to find a solution.
I like the laptop except for one or two issues, I just want to be able to kill the throttling.
n0b0dykn0ws
PostPosted: Wed Sep 03, 2008 3:58 am
Why do you want to do that? it saves your battery..
PostPosted: Wed Sep 03, 2008 4:14 am
Team Dino
Team Dino
I want to disable it when I'm running off AC.
As of right now, it still runs while on AC.
n0b0dykn0ws
PostPosted: Fri Sep 05, 2008 11:00 pm
Team Dino
Team Dino
No suggestions at all?
BTW: I want this to be free.
n0b0dykn0ws
PostPosted: Sat Sep 06, 2008 9:12 am
...is your laptop too slow?
its probably in your BIOS, or maybe..maybe.. the software installed on your laptop by HP. besides, your CPU should speed up when you're doing something
PostPosted: Sat Sep 06, 2008 9:43 pm
Team Dino
Team Dino
Not in the BIOS.
Things HP has had me try:
Change to "High Performance" in the Power Options. Did nothing.
Turn it off in the BIOS. Not there.
Remove an application. Application not installed.
Create a registry key and flash the BIOS. Still throttling!
BTW: Who should I believe? An independent company or the company that made unreliable CPU throttling?
n0b0dykn0ws
