It is currently Wed May 06, 2015 9:51 pm
 Post subject: CCNA/CCNP Lab Setup
PostPosted: Sun Jul 20, 2008 6:00 pm
Hey everyone...I am looking to further my career goal and become CCNA and CCNP certified within the next year or two and need a little advice. I have simulators and the books but nothing can replace hands on learning especially in an interview situation. So my question to you guys is what do i need to setup a CCNA/CCNP lab to learn on? I am not familiar with CISCO networking so please give specifics on what routers and such that I will need. Also I would like to keep a resonable budget of less than 700 if possible.
Thanks
G
PostPosted: Mon Jul 21, 2008 8:04 am
Cisco routers cost thousands .. often tens of thousands ... of dollars.
Well, they do make hardware for SOHO that costs under $500 but you don't need any hand's on work with a router that has 8 ports and a couple of settings.
You would benefit, I'm sure, from playing with their more advanced hardware (which have everything from hardware based IPTable security, built-in SBCs and VoIP gateways) .. but those are well outside your budget.
Here is an example of some Cisco products for sale as cheaply as I can find: link
 Post subject: I See
PostPosted: Mon Jul 21, 2008 2:54 pm
I am not talkking about getting brand new stuff. I want used if i can get it.
I am sure i read somewhere that you need at least 2 routers and a switch? Then there was a link to buy a router 2509? sound right? And it was like 90 bucks or something like that.
Thanks
G
PostPosted: Wed Jul 23, 2008 4:53 am
TravBv2.0
TravBv2.0
My CCNA book suggested picking up some Cisco 1841 routers or 2800 series routers. There are several simulators you can use, both propietary and open-source, so take your pick.
PostPosted: Mon Sep 01, 2008 12:27 am
Location: Folding as QQue - que'ing up #300 of pork and beef
Go out on eBay and there are a couple of sellers that specialized in used equipment bundled for intro CCNA or you could mirror them and piecemeal a lab yourself.
