It is currently Sat Jan 31, 2015 5:41 pm
 Post subject: Hot Hot Laptop
PostPosted: Sat Jul 10, 2004 3:48 pm
Ok first of all i have this Fujitsu N Series notebook. it is the 3010 model with all the goodies but the built in wifi. Anyways, i noticed that on the bottom of my notebook where the ram is placed, it gets real hot. Its a small tab with a screw that when removed reveals the ram slots and the stick of ram. My question is this, since my laptop is turned off about 2 times a year (w00t) will it envntually damage the system with all the heat? Or is it ok, seeing as my ram is being cooled with the internal fan (right?) I have an Antec cooler thing also but i hate to use it cause its so damn clunky and HUGE! Any opinions?
PostPosted: Sat Jul 10, 2004 3:51 pm
BTW...HELLO EVERYONE! Been reading MPC for ages...just joined today.
PostPosted: Sat Jul 10, 2004 4:00 pm
just make sure that iar can get to the intakes (usually on the bottom of the laptop)
if you are really worried, you can get a laptop cooler, which is basically fans under the laptop
PostPosted: Sat Jul 10, 2004 4:03 pm
Yea i said i have the Antec Laptop cooler. Ive ran the laptop for a long time and nothing really happen to it. but im affraid of the heat it creates. if the laptop just sits there and there nothing blocking the passages underneath then it should be fine right? i mean why would they sell a laptop thats gonna malfunction cause air isnt entering the system?
PostPosted: Sat Jul 10, 2004 4:31 pm
Anymore help on this?
PostPosted: Sat Jul 10, 2004 8:51 pm
If your laptop is stable, don't worry about it man. most laptops get really hot these days.
My brand new Dell gets pretty toasty after a while.
PostPosted: Sat Jul 10, 2004 10:09 pm
Yea its stable....but man i can make some eggs on this thing....lol
PostPosted: Mon Jul 12, 2004 1:37 pm
King of All Voodoo2 Cards
Don't worry about it.
I've had a very hot desktop processor in mine running for over three years and there's no damage yet.
PostPosted: Mon Jul 12, 2004 3:43 pm
i wouldnt worry about it then...just put it in stand-by when not really using it
have the monitor shut-off instead of a screen saver, and have the disks spin-down after some period of time
PostPosted: Wed Jul 14, 2004 6:40 am
What's the ambient air temp? If you're 70-F, you should be okay. If you're at 80-F, then you could be decreasing the life of the notebook components. Heat= t3h bad.
PostPosted: Wed Jul 14, 2004 9:37 am
If you're really concerned you can always call up the company and tell them and ask them if this is normal. Some LTs get very hot at the bottom.
PostPosted: Thu Jul 15, 2004 11:57 pm
well i have called fujitsu and they said that its normal. Also asked other people with laptops and thiers get real hot also. Maybe one day ill buy one of those laptop to lifters so that air can flow thru it better.....
