It is currently Sun Jan 25, 2015 10:38 pm
 Post subject: Installing RAID 1
PostPosted: Sat Jul 10, 2004 1:13 pm
I just bought a RAID 1 card for my computer (dell hooked me up with what I needed) and I have two identical hard drives. I want to know if I completely delete drive D, and leave the OS and everying on C will I be able to start the RAID 1 and have the C drive copied over to D. I guess my question is do I need to erase both drives or can I just erase the D drive - because erasing both would be so much more of a hassle.
PostPosted: Sat Jul 10, 2004 2:19 pm
When you go into the raid bios and setup your array the bios warns you that everything will be wiped on your drives, do you want to continue?
When you remove these drives in the future, be sure to break the raid array in the raid bios before using the hard drives by themselves because you will have a hard time formatting the drives later.
PostPosted: Sat Jul 10, 2004 3:13 pm
No, when you set up a RAID array all data on the two drives is deleted.
If there's anything you want to keep you'll need to back it up to another computer or onto some other media (CDs, DVDs, etc).
PostPosted: Sat Jul 10, 2004 3:32 pm
thanks for your info, not the answer I wanted, but thanks anyways
PostPosted: Sat Jul 10, 2004 3:52 pm
They are both going to be erased when you assign the array, no matter if you have already formatted them or not...
