It is currently Tue Jan 27, 2015 9:38 am
 Post subject: The Microsoft Certified Desktop Support Technician (MCDST)
PostPosted: Fri Apr 18, 2008 6:19 pm
I've been looking at this along with taking the A+ test. Is it a hard test to past any advice
PostPosted: Sat Apr 19, 2008 6:36 pm
its hard if you dont know what you need to know...
PostPosted: Wed Apr 23, 2008 6:15 am
I took it back in November. I took the course in school and didn't really pay attention to the course, the 70-271 course i didn't even go through the book. Download a testking for it, make sure you have the latest version.
PostPosted: Wed Apr 23, 2008 6:29 am
testking is a good tool but if you were to get a job and u need to know microsoft lol your in shit if you didint pay attention
PostPosted: Wed Apr 23, 2008 7:47 pm
Malware specialist
Malware specialist
Remember certifications alone are not going to get you a job.
You also need practical experience, which is going to help you keep the job. The certifications may get your resume looked at though.
All these certifications state is you have enough brain's and technical experience to pass the test.
PostPosted: Thu Apr 24, 2008 2:40 am
+1 for this.
I'm taking my MCDST for work. I work with it everyday, but the cert. is just there to make me look good. 8) :lol:
PostPosted: Thu Apr 24, 2008 5:16 pm
+1 for this.
lol there you go go fade...
and thats why in my A+ Cert guide i say you need one, the theory two, the hands on work
PostPosted: Fri May 23, 2008 5:23 pm
TravBv2.0
TravBv2.0
I too looked at the MCDST cert, but the 70-271 was very similar to the 70-270 , which is a beginning point for an MCSA. And all the 70-272 test is just knowing MS Office inside and out. If Office is something you must know for your current job, then the MCDST sounds like your bag, but I don't think this cert alone, or coupled with the A+ will get you a non-retail IT job.
PostPosted: Wed Jul 02, 2008 10:36 am
Having 70-270 probably has more weight than MCDST...why...because employers will look specifically at a Windows XP specific cert with a bit more weight. And most have never seen or heard of MCDST. It's actually a fairly easy cert to get, but the 70-270 is actually fairly tough, given it goes over Remote Installation Services and deploying images quite a bit.
In fact, MCDST is usually called "Mc DST", like McDonalds because it's fairly easy to get.
