It is currently Sat Mar 28, 2015 11:07 am
 Post subject: whats the most overclocking can u get out of a eVGA 6600gt ?
PostPosted: Sat Nov 27, 2004 12:25 pm
Can you overclock a 6600gt into a 6800 :?:
PostPosted: Sat Nov 27, 2004 12:27 pm
Contributing Writer
Contributing Writer
Overclocking the core and memory will vary, but you're out of like in the pipeline department. 6800GT = 16 pipes, 6600GT = 8.
EDIT: Read the thread, you'll see.
PostPosted: Sat Nov 27, 2004 12:29 pm
o ic :D
PostPosted: Sat Nov 27, 2004 1:12 pm
should have gone with the xfx chip based on the 6600Gt core, sports an already overclocked stats, plus a big honking heatsink
Chipset/Core Speed: nVIDIA GeForce 6600GT/500MHz
Memory/Effective Speed: 128MB GDDR3/1000MHz
BUS: AGP 8X
Ports: TV-Out (S-Video) + 2x DVI
Support 3D API: DirectX 9(Shader Model 3.0), OpenGL 1.5
Max Resolution@32bit Color: 2048X1536@85Hz
Cable/Accessories: S-Video Cable, 2x DVI to VGA adaptor, Manual, Driver CD, Games and Softwares
I'v heard of overclocking to 570/1100, stable, no artifacts!
for 270
plus it come with a Free GIFT ITEM|AQUARIAS ZODIAC PAPER WT when you buy XFX nVIDIA GeForce 6600GT Video Card, 128MB GDDR3, 128-Bit, Dual DVI, AGP 8X, Model "PVT43AND" -RETAIL
http://www.newegg.com/app/viewProductDe ... 080&depa=0,
but i couldnt use it, im a virgo :roll:
PostPosted: Sat Nov 27, 2004 2:32 pm
Celeron
Celeron
One4yu2c wrote:
Overclocking the core and memory will vary, but you're out of like in the pipeline department. 6800GT = 16 pipes, 6600GT = 12.
Actually... Revise the numbers! :P
PostPosted: Sat Nov 27, 2004 3:51 pm
Contributing Writer
Contributing Writer
How's this?:
6600GT: 8 pipelines
6800GT: 16 pipelines
I had the 'nu' on the brain :D
PostPosted: Sat Nov 27, 2004 4:45 pm
so we have probably come to the conclusion that you cant overclock it more than 60/100 tops, hope you got a water cooler!
