It is currently Sat Jan 24, 2015 8:08 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: Rig Of The Month
PostPosted: Sun Jun 17, 2007 8:33 am
I'd rather be modding!
Think you have a contender for Rig of the Month at Maximum PC?
Well do ya?
Send a 300 word write up and high resolution images (I suggest at least 4) to:
rig at maximumpc.com (you know the "at" drill - no spaces)
The write up must be in english. If you are ESL, using a BabbleFish, or just want help, I suggest you post your writeup in the forum for member editing before you send it off. Members can help you "tweak it up".
(Because I write the Mod_Blog, I can't help you much other than maybe spelling).
The prizes change often, but are typically worth $500!
Manta
PostPosted: Sun Jun 17, 2007 12:00 pm
Worked for me, your turn!
PostPosted: Mon Jun 18, 2007 7:43 am
Monkey Federation (Top 10)*
Where does the 300 word essay go? All I ever see is 3-4 sentances in the mag about the monthly rig.
PostPosted: Mon Jun 18, 2007 11:24 am
Basically, they use it to make the write up. Maybe pull a quote or three from it.
Manta
PostPosted: Mon Jun 18, 2007 12:02 pm
Manta
Dang it. For a moment there I was getting excited for expanded coverage in that section of the mag....
PostPosted: Thu Jul 05, 2007 7:10 pm
o snap! once I'm done with mine (hopefully I finish...) im submittin it for sure : )
PostPosted: Wed Oct 24, 2007 9:05 pm
o snap! I finished it. better get to writing this up : )
PostPosted: Tue Nov 06, 2007 10:49 am
I submitted my SuperBee PC :D
PostPosted: Thu Jan 03, 2008 11:51 pm
ya I have plans to enter my FEAR build :D
Its late but I will get started on the entry requirements tomorrow.
PostPosted: Sat Jan 12, 2008 1:15 am
the current $500 gift card is to ewiz.com... but ewiz doesnt seem to sell anything :( is there a possibility of it changing soon?
PostPosted: Sun Jan 13, 2008 12:09 am
In the mag it says "one entry per household". Does that mean that I can only enter one of my mods? I have several to enter, and I plan on doing many more (better) mods, so should I wait and only enter the best one?
PostPosted: Mon Jan 14, 2008 10:59 am
Hmmm....
Good question - I'll look into it.
PostPosted: Mon Jan 14, 2008 6:03 pm
You can submit a dozen if you like, but only one can get accepted. When you do make it in the mag, you cannot enter for another 6 mos or so.
PostPosted: Thu Jan 17, 2008 6:51 pm
has anyone here ever shopped at ewiz.com? im thinking about submitting my case but would rather wait for the website to change. maybe www.performance-pcs.com would be better? www.frozencpu.com? www.xoxide.com? those are probably the 3 best modding supply stores in the USA
PostPosted: Fri Feb 01, 2008 9:13 pm
Yup. Fine prices, excellent support. They'll check things by hand if they need to.
Cases can be had probably cheaper than most at SunDialMicro.com, also great service.
 Post subject: Betty
PostPosted: Mon Mar 17, 2008 7:18 pm
HOW DO i SUBMIT MY RIG OF THE MONTH?????????
 Post subject: Re: Betty
PostPosted: Mon Mar 17, 2008 8:47 pm
The first post in this tread tells you how, or it is also in Maximum PC issues on the last page of the mag.
PostPosted: Wed Mar 19, 2008 5:39 pm
My SuperBee PC will be the May RotM!
PostPosted: Thu May 08, 2008 4:51 pm
Congrats!!!!! They never like any of my builds :(
PostPosted: Thu May 08, 2008 8:53 pm
Keep trying :) It's worth the little time it takes.
