It is currently Tue Apr 21, 2015 3:29 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: OOPS
PostPosted: Thu Jul 08, 2004 2:04 pm
I accidentally deleted a file I didnt want to delete.
I did a SHIFT+DEL.
How do I get it back? A no cost solution would be best.
Thanks.
PostPosted: Thu Jul 08, 2004 2:18 pm
if MS money is giving your a problem, try uninstalling the program and installing it again. if this doesnt work post back here and ill see what i can do you help you out. good luck
PostPosted: Thu Jul 08, 2004 2:54 pm
I already tried that.
I even tried starting a new file, but as soon as I set up all my accounts and whatnot I pops up with the error again.
PostPosted: Thu Jul 08, 2004 2:55 pm
I still need to get the file back though...
PostPosted: Thu Jul 08, 2004 3:23 pm
Monkey Federation (Top 10)*
I left MS Money a year ago, when I realized it would never stop crashing. I would suggest investing a little (I know you said free fix) and getting Quicken. It is way teh better.
 Post subject: Re: OOPS
PostPosted: Thu Jul 08, 2004 3:53 pm
SomeGuy wrote:
So MS Money has been being a bitch and everytime I start it, it gives me an error and shuts down. It worked fine last night, for the past two weeks, etc etc.
In any case, I accidentally deleted a file I didnt want to delete.
I did a SHIFT+DEL.
Thanks.
What's the error?
If you deleted the file, check to see if it had a backup save otherwise I'd say you're SOL
PostPosted: Thu Jul 08, 2004 4:42 pm
I dont give a crap about Money or Quicken at this point.
I need the file back (a non-Money file).
Shiftey and Monkey, try re-reading my original post, maybe you will understand my actual question.
PostPosted: Thu Jul 08, 2004 5:05 pm
Contributing Writer
Contributing Writer
I did a SHIFT+DEL.
Thanks.
How big is the file? The trial version of Quetek's File Scavenger will recover files up to 64KB, and it works extremely well:
http://www.quetek.com/download.htm
PostPosted: Thu Jul 08, 2004 5:22 pm
One4yu2c wrote:
I did a SHIFT+DEL.
Thanks.
Its greather than 64KB :\
I tried Restorer 2000 or something like that and it had the same size limitation for the demo :\ It saw the file though.
I just dont want to pay $39+ to recover a SINGLE file. Its not THAT important, it just has all my usernames and passwords for all the forums and webpages and whatnot in it...
I mean its important...but not $40 important.
PostPosted: Thu Jul 08, 2004 5:38 pm
Contributing Writer
Contributing Writer
Tartar sauce. :(
You may have already given Logik's listings a peak, but if not, he's got a handful of data recovery links in there. You may luck out and have one of them give a bigger size restriction? I'll dig around a bit, but I'm not likely to stumble upon anything you haven't found yourself.
http://www.ultratech-llc.com/KB/?File=/undelete.txt
PostPosted: Thu Jul 08, 2004 6:00 pm
One4yu2c wrote:
Tartar sauce. :(
Yeah, maybe so.
I think if there is one with a 128KB+ size limit, it will work...
PostPosted: Thu Jul 08, 2004 6:20 pm
Well I looked at all the ones in Logik's links.
Either the Demos dont recover the files at all, or they dont recover files larger than some insanely small file size (one wouldnt do anyhting under 2KB).
PostPosted: Thu Jul 08, 2004 6:47 pm
I did a SHIFT+DEL.
Thanks.
Go to simtel.net and look for a program called Handy Recovery. There is version 1.0 and 2.0. 1.0 is freeware and is a data recovery program. A program like this is your best chance.
PostPosted: Thu Jul 08, 2004 7:03 pm
Contributing Writer
Contributing Writer
Handy Recovery looks promising. From my reading on their site, it looks like you can recover 1 file per day on the trial version (no mention of file size), and also they link the freeware version of 1.0. Well done baldeagle!
http://www.handyrecovery.com/download.shtml
PostPosted: Thu Jul 08, 2004 7:14 pm
baldeagle wrote:
I did a SHIFT+DEL.
Thanks.
IT WORKED!
Thanks!
 Post subject: File Restore
PostPosted: Fri Jul 09, 2004 4:42 am
Go to this web site and you'll be able to recover NTFS files for free but only if they doen't exceed a certin limit, they you have to buy but still very cheap.
http://www.quetek.com/prod02.htm?source=overture
File Scavenger
 Post subject: Re: File Restore
PostPosted: Fri Jul 09, 2004 5:09 am
Contributing Writer
Contributing Writer
File Scavenger
Pssst. Read the thread.
PostPosted: Fri Jul 09, 2004 7:33 am
Yea, I read the original question. Pull out the stick in your ass. Deleting deletes stuff. You Oops Big Time.
PostPosted: Fri Jul 09, 2004 8:15 am
I edited my post just for you guys.
Deleting doesnt REALLY delete stuff.
Hence I got my file back.
*sticks tongue out*
PostPosted: Fri Jul 09, 2004 8:40 am
*sticks tongue out*
LMAO! NOw some no0b is going to come by interested in getting MS Money and won't know that it is a piece of shit.
But wait.... You mean when I hit the delete key, the thing doesn't really dissapear into nothingness? Crap. I need to figure out a better method of getting rid of my pr0n. LOL
