It is currently Wed May 06, 2015 10:01 pm
 Post subject: Connecting Remotely to Windows 2000 Pro
PostPosted: Thu Jul 08, 2004 2:00 pm
Hello All,
I have a question. First I connect to my customers server(Windows 2000 Server) via remote desktop from my pc. (XP PRO). I then use terminal services client to connect to another workstation at the same location.I have no problems doing this when connecting to a XP pro machine. I just enable remote desktop. Is setting up remote desktop the same on 2000 professional? What is the best way to connect to a 2000 pro clinet machine from the server?
Is this confusing? I can try to explain better if needed. Thanks for any help.
I also posted this at delphi, because i wasnt sure how many people are at each board.
Thanks, Jason
PostPosted: Thu Jul 08, 2004 2:09 pm
Since Win2000 does not come with Remote Destop Connection, you need to install it. Unfortunetly, I can't find the download for you, but it exists somewhere...
PostPosted: Thu Jul 08, 2004 2:47 pm
I have the install program from microsoft. So when i install it... I will have the option like in windows xp under my computer properties, remote, to accept incoming connections? Thanks for the info.
PostPosted: Thu Jul 08, 2004 7:24 pm
Yeah, it should work essentially the same.
 Post subject: Re: Connecting Remotely to Windows 2000 Pro
PostPosted: Sat Jul 10, 2004 9:09 pm
The Logik! Bot
The Logik! Bot
Remote Desktop/Terminal Services can be use to connect FROM any version of 32-bit Windows, with the destination being any of the following:
* NT4 Terminal Server
* 2000 w/Terminal Services enabled
* 2003 w/Remote Desktop (or TS) enabled
* XP Pro w/RD enabled
To connect *to* a 2000 Pro system, you need to use NetMeeting or a 3rd party solution.
http://www.ultratech-llc.com/KB/?File=RemoteCtrl.TXT
PostPosted: Sat Jul 10, 2004 10:50 pm
Thanks again. I got your reply on delphi. Thanks for the info!
