It is currently Fri May 24, 2013 5:26 pm
 Post subject: Recommended DVD Burning Software
PostPosted: Wed Oct 10, 2007 5:47 pm
So I finally got a DVD burner after umpteen years of not using one (omg!) and I have some AVI files I would like to burn to DVDs. Now, I have the files converted to DVD format (VIDEO_TS, AUDIO_TS) that part is no problem.
The problem is, I need a good program to use to burn them to a DVD. Do any of you have preferences, if so why? I have Nero that came with the DVD burner that I purchased (Nero 7 Essentials) however I haven't enjoyed Nero in the past with other uses.
Thanks in advance.
PostPosted: Wed Oct 10, 2007 8:10 pm
like a rock - waitaminute, I AM a rock
I use Nero Burning Rom 6.6.1.4 for most of my DVD burning. I've been using Nero 6 for years now. I purchased Nero 7 and really didn't like it much. So I put Nero 6 back on the next comptuer build I did and I've been using it ever since.
If it ain't broke, don't fix it.
PostPosted: Wed Oct 10, 2007 10:40 pm
Smithfield*
Smithfield*
Lollers, same for me, even same version. I heard not so good things about Nero7, and i figured why bother to change anything when nero6 has always done me well?
According to Ahead's site Nero6 is discontinued, but you can still find it around for cheap.
PostPosted: Fri Oct 12, 2007 7:05 pm
Here's another vote for Nero 6. But to burn DVDs I use a combination of DVDShrink and DVD Decrypter burning ISOs. Bulletproof.
PostPosted: Mon Oct 15, 2007 11:47 pm
CloneDVD by Slysoft
