It is currently Thu Jan 29, 2015 5:32 pm
 Post subject: Dual monitor/ dual video cards want two different views.
PostPosted: Thu Jul 08, 2004 8:14 am
I recently installed an ATI radeon all in wonder 85oodv in my AGP slot.
I reset my bios to first go AGP.
My old card, which I removed, Was a PCI nvidia card.
When I tried to set up the nvidia card with a second monitor, I got error messages regarding drivers for the Radeon and the nvidia/second monitor never worked.
In display properties I could see a Radeon as monitor 1 and three and the nvidia as 2 and 4 (sometimes it said default monitor for the 2 & 4).
In device manager I could see both cards.
I took the pci card out and gave up.
Using XP pro.
Any thoughts will be appreciated.
 Post subject: Re: Dual monitor/ dual video cards want two different views.
PostPosted: Thu Jul 08, 2004 8:29 am
Using XP pro.
If I read this correctly, were you trying to use both the ATI and Nvidia cards to run a dual monitor setup?
If so, that probably won't work because the ATi drivers are not going to send output through your Nvidia card.
See if you can find a Radeon VE (read: cheap ATI PCI card) and try that.
PostPosted: Thu Jul 08, 2004 8:33 am
yes I was. two cards, two monitors, one computer. two sets of drivers.
PostPosted: Thu Jul 08, 2004 9:09 am
i've used an Nvidia card for a 2nd monitor with an ATI card as the primary card. i never did have driver conflicts though
