It is currently Wed Jan 28, 2015 11:38 am
 Post subject: CASE MOD BASICS: Case Window Install Video
PostPosted: Sun May 27, 2007 5:24 pm
Hey Gang, Heres the first in a series of diy videos where I go "Back to Basics" and share my techniques. It's always good to refresh yourself once in awhile :)
DO-IT-YOURSELF CASE WINDOW & INSTALL
PostPosted: Sun May 27, 2007 6:04 pm
Monkey Federation (Top 10)
Thanks for sharing with us Bill, always good to keep the basics
fresh. Everyone wants to get too fancy with some of their window
mods (not always a bad thing, but simpler is better sometimes).
PostPosted: Sun May 27, 2007 6:37 pm
Same-Same...always have the love for what you have to give us man!
PostPosted: Mon May 28, 2007 4:34 am
Thank you guys! :D
Please post any suggestions for more "Basic Diy Mods" you would like to see.
Improving your Case Cooling is already on my "To Do List" :D
PostPosted: Mon May 28, 2007 5:05 am
Improving case cooling is pretty broad ;)
I'd like to see:
Install a blow-hole, 12cm fan with grill.
Install a vandal-proof switch (both regular, and LED types)
Install a CCF light
Install a remote open/close switch on an optical drive
Etch a design on plexi / glass
Install mesh (anywhere)
PostPosted: Mon May 28, 2007 6:27 pm
how-to-hide wires the right way i need that one bad
how-to-make the atx mobos work in old cases they shouldnt go in you guys make seamless. thanks again bill you the man
How-to- put led lights ,ccfls,lighting to give off best effect
PostPosted: Tue May 29, 2007 5:43 pm
Very cool. Just watched the whole thing. New here 1st post ^^
PostPosted: Tue May 29, 2007 6:45 pm
hello and welcome
PostPosted: Fri Jun 01, 2007 11:54 am
Thanks for all of the great suggestions! :D
I've also had a lot of requests for a video version of my Turbine Fan Tutorial
It would utilize a 120mm intake fan
PostPosted: Fri Jun 01, 2007 2:38 pm
Thanks for the vid.
:D
PostPosted: Fri Jun 01, 2007 7:42 pm
It would utilize a 120mm intake fan. that would be awesome
PostPosted: Mon Jun 04, 2007 3:38 am
You bet!
Yes, and it will be painted Mopar Challenger Orange or something similar 8)
PostPosted: Tue Jul 31, 2007 10:38 pm
did he say he got that plastic from nick naster ? or mic master ? any one know?
PostPosted: Wed Aug 01, 2007 3:22 am
http://www.mcmaster.com
Once there, goto bottom of right hand column of screen, acrylic sheets are listed under "Raw Materials" as "plastics"
another good source for acrylic sheets,
http://www.delviesplastics.com
PostPosted: Thu Aug 02, 2007 7:59 am
thanks
PostPosted: Sat Aug 04, 2007 4:35 pm
You can aslo buy acrylic sheets from USplasitcs
