It is currently Tue Jan 27, 2015 8:20 pm
Post new topic Reply to topic  [ 591 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 30  Next
PostPosted: Sun Aug 15, 2004 8:56 pm
P4 2.8C @ 3.5, 250fsb 1:1 is my best OC with this rig, currently have it backed down to 3.36 (240fsb) 1:1 with 1 GB Geil PC4200. Ran stable and cool enough at 3.5, just figured 3.36 would probably help the chip last a little longer (as well as keep the room a little cooler) in the summer heat.
PostPosted: Wed Aug 18, 2004 6:27 pm
Here is a discription of my OCed rig with some links to back it up and yes this is a 24/7 rig :twisted:
Cooler Master 110 case w/window and cold cathode
Sony E540/ 507 Mach2
Asus A8V FX53 256x11.5@2.952 24/7
OCZ 3700EB 2x512@2.9v 1/1
9800XT w/V-mods MCW50-T 172w pelt@24v 560/438
4 80g Maxtors in raid0+4 stripe/Promise Fastrak TX2000 controller
SoundBlaster Audigy/Klipsch 4.2's/US Robotics modem/
Lite-On CD-RW/Lite-On DVDRW SOHW-8325
TTGI 520w 3.3 rail mod
http://service.futuremark.com/compare?2k1=7977294
http://service.futuremark.com/compare?2k3=2788677
And a screen shot that I have posted at anouther site http://www.xtremesystems.org/forums/sho ... post524078
PostPosted: Mon Aug 23, 2004 11:49 pm
I did a normal o'c 2500+ to 3200+
PostPosted: Tue Aug 24, 2004 3:31 am
Professional Dork
Professional Dork
Just hit 3.3 with my 2.4C; 275 fsb.
PostPosted: Wed Aug 25, 2004 3:15 pm
hmm overclocking, sounds like something you should be paid time and a half for
PostPosted: Thu Aug 26, 2004 12:12 pm
Team Creamsicles
Team Creamsicles
cpu 1: amd athlon xp 2600+ oced to abt 3200+ in the winter but in summer oced to abt 2800+ ( brother oced it)
cpu 2: amd athlon64 fx-53 2.4ghz oced to abt 2.51 (my brother cpu, he oced it)
my brother oced the cpus the athlon xp is mine
Last edited by GreenMidgetYoda on Thu Aug 26, 2004 12:58 pm, edited 1 time in total.
PostPosted: Thu Aug 26, 2004 12:38 pm
i got bored of overclocking a long time ago
pentium 120 - 150 MHz
pentium 166 - 180 and 200 Mhz on a hardcore overclocker freak day dipswitch changin jumper pushing mofo
amd k6-2 400 to 450 and 500....after a while 500 starting acting funny so i dropped it down to 450
i dont overclock cpu's anymore .... :D
PostPosted: Thu Aug 26, 2004 4:02 pm
BANNED
BANNED
Intel P4 3.0Gig 800Mhz FSB, clocked to 3.6Gigs, and 960 Mhz FSB. All with air-cooling. And it's as far as I can get without water cooling...which is in the works, but for my LGA775 3.6Ghz system.
PostPosted: Sat Aug 28, 2004 2:30 pm
on my old trusty xp2500 i got up to xp3200 on def volts of 1.65. i tried going over, and made it as high as 230x11 (2530mhz), but it wasn't stable at all. very unpleased with not being able to break 200mhz (i couldn't get any stable overclocks over 200fsb), i sold my heatsink and processor last monday to a guy for $65 and am buying a mobile xp2600 with a thermalright sp-97 coupled with a neo backplate and a vantec tornado 92mm. i will report my speeds back when i get this beast so you can all be jealous :D
PostPosted: Sun Aug 29, 2004 5:45 pm
Celeron
Celeron
im guessing you're using pc-3200 ram.
if you are, then you hit the limit on your ram, since pc-3200 ram is only rated for 200mhz (ddr400) and below.
 Post subject: Mobile Barton
PostPosted: Sun Sep 26, 2004 10:54 pm
AMD AthlonXP 2500+ Mobile @ 2.4ghz on an Asus A7N8X Deluxe. :)
Does more than I need it to..
 Post subject: Mobile 2500+ @ 2.5 Ghz (200*12.5) 1GB dual-channel
PostPosted: Tue Oct 05, 2004 8:23 pm
Along with a modded X800Pro (to XT) running at 550 core / 575 RAM
(runs DooM 3 really nice :)
2*36 GB Raptors in Raid0 for OS
4*80 GB SATA 'Cudas in RAID0 for data (the hell with data safety, let's dangle the baby from the balcony :)
PostPosted: Fri Oct 08, 2004 10:03 am
Max [Ph]otographer
Max [Ph]otographer
2500+ (1.83ghz) @2299mhz :D
That's with a VDIMM bump of .2v, and a CUP voltage bump of .175v
Last night it reported 51C CPU and 30C Mainboard, today is a different story though becuase it got warm again.
Dan O.
 Post subject: That's funny
PostPosted: Sat Oct 09, 2004 8:15 pm
Raven wrote:
I dont overclock, it's the work of Satan
That sounde a lot like "the church lady" from SNL LOL!
PostPosted: Sun Oct 10, 2004 6:52 pm
Crap!, I don't know how to overclock my CPU with the Intel D875PBZ motherboard, I think it's locked or something, I can't find in the bios nor jumpers as to how the heck I should.
I should've got an ASUS, but I'm pizzed at ASUS, my 845PE chipset mobo broke and they send me one with an old bios and I didn't like that crap. It's like buying a car with a V6 engine and send it back for repair and you get it back with an I4, that's the way I saw it and didn't like that at all.
Back to the issue, how do I overclock with an Intel mobo with the 875 chipset?, are the Intel mobos locked?. :?
PostPosted: Wed Oct 13, 2004 5:56 pm
Scr#$ overclocking. My HP Pavilion 8765c 900Megahertz Athlon Thunderbird that I bought way back in 2000 is used for playing demanding games (e.g.
Far Cry, Sims 2, Silent Hill 4) at full detail at pretty good frame rates at 1024 x 768 with an slightly overclocked PNY GeForce 5700 le and 256 megs of ram with windows ME and you know what? I AM STILL SATISFIED WITH IT! I know a lot of you are snickering because of the brand name and ancient technolgy, but it has seen me through my most demanding tasks without fail. But alas, the writing is on the wall and its time to give it a well deserved retirement and upgrade so I can finally play DOOM 3 (which requires Windows XP). :cry:
PostPosted: Thu Oct 14, 2004 10:44 pm
amd 2500 mobile at 250x11 1.95v*2.76gig*
 Post subject: hmmm
PostPosted: Wed Oct 20, 2004 2:23 pm
I have my AMD 486 dx4 100mhz Oced to 133mhz
PostPosted: Sat Oct 30, 2004 3:47 pm
8) xp2600 at 2200mhz. with 1.6 on vcore!! 900u for hs,idles at 33.c, and load at 38.c ( SUMMER), (winter)= idle at 28.c, and loads at 32.c
needs better mobo(xmas!!!) to run at 24xx"s have kt400 right now:(
PostPosted: Thu Nov 04, 2004 3:53 pm
overclocking sucks, do the thing that everyones doing, UNDERCLOCKING!!! I'v underclocked my cpu from 3.2 to a 2.5 and still going OH YEAH!!!
