It is currently Mon Apr 27, 2015 8:36 pm
Post new topic Reply to topic  [ 96 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed May 24, 2006 7:09 am
more pics
http://www.pbase.com/cypher22/pc
 Post subject: Project: Mechaniod
PostPosted: Fri Jun 02, 2006 9:20 pm
Mechaniod is finally finished!!!
I hope every one likes it, it's my first mod.
Note, wire management is not my high point.
PostPosted: Thu Aug 17, 2006 3:43 pm
Man there are some bad ass computers on here I dont know how you guys do it but ITS AWSOME STUFF keep the good work up
PostPosted: Thu Aug 17, 2006 4:28 pm
Dangitt! I really have to get on the ball.
PostPosted: Fri Sep 01, 2006 10:03 pm
Finally posting them so, here are my PC Mods.
R2D2 PC
Paradise Lost
Lord of the Rings
UFO Mod
The Matrix
Care Bear PC
Turbine PC
Craftstick Airplane PC
Mother-Bored
El Diablo
Hard Drive PC
CLOWNED
SUPER.BEE
PostPosted: Fri Oct 20, 2006 12:36 pm
Team Member Top 100
Team Member Top 100
Care bears?! LOL
PostPosted: Tue Nov 14, 2006 2:07 pm
I'd like a short rant in something labeled "OMG":
Dark lit rooms for a photo is lame. It just shows you have $30 invested in lights and no real work. If that makes "OMG", then I'm lost. I see some great work, but only one photo shows that awesome work...the rest show light throw some hole in the case.
Just my negative post of the day.
PostPosted: Fri Nov 17, 2006 2:04 pm
Monkey Federation (Top 10)*
You certainly can't be talking to TheGreatSatan... He just through up like 40 mindblowing mods.
PostPosted: Thu Mar 08, 2007 1:56 pm
X6800 on stock Vapochill LS
dual 8800GTXs on DD blocks
4 gigs OCZ 1066 RAM
Vista drive: Two 150 gig Raptors in raid 1
XP Pro Drive: 750 gig Seagate
Storage: 750 gig Seagate
Thermochill PA 120.3 Rad with 6 SilenX fans in push/pull
7 other SilenX Fans mounted thru the case
Custom Mountain Mods 22" Cube built around Vapochill and 12" Elo TouchScreen LCD monitor
All windows laser etched by MountainMods, case painted by Smooth Creations
3dMark06 around 17500 @ 4.2 ghz
(didn't save that score but this one is close http://service.futuremark.com/compare?3dm06=1288813 )
Here are a few pix (I know most people hate the design . . .such is life . . .did it for me and the wife):
Before painting:
After painting:
Conformal spraying teh mobo to protect against condensation:
Fan for SB:
Finished Product:
In its natural habitat (it is an HTPC): Image
And, yes it is heavy: Image
PostPosted: Thu Mar 08, 2007 3:17 pm
Why did you cary it when it has wheels?
PostPosted: Thu Mar 08, 2007 4:01 pm
Look at the floor. Its carpet.
PostPosted: Thu Mar 08, 2007 6:21 pm
PostPosted: Thu Mar 08, 2007 6:56 pm
Trav, I want you to make it your personal mission to stop making crappy posts and saying stupid things.
So, logically yes casters work on carpet. However, considering the height of the PC and the lack of a handle it would be difficult to push. Also, carrying is preferrable when navigating through people, doors, and up and down stairs or over doorsills. And it saves having to lift it up past each of these obstactles. Also, those are plastic wheels. They aren't meant to roll long distances. They are only there to provide limited mobility. Those kinds of plastic wheels are prone to bending and breaking under use, which would render them completely useless, and that's just not good now is it? Also, who is to say that they're carrying it anywhere. maybe they DID roll it to that spot. Maybe they're simply lifting it onto a table, or putting it in/out of a vehicle.
Please, think once in a while. I'm sick of your posts that you put no thought into. I realize you're like 14 but theres no excuse not to be a mature, insightful individual.
PostPosted: Thu Mar 08, 2007 7:18 pm
I also did not want everything bumping around more than neccessary in the case. The floor was not totally flat. I am thinking about having a steel table made for the rig that I can attach it to and remove it from with better wheels on the bottom. The table would be painted to look like wrought iron with rather gothic touches to it.
Now please don't ask me about the rug burns ;)
PostPosted: Fri Mar 09, 2007 10:15 am
Do0d, that is a sweet idea. I've never seen anything like that for a PC before.
PostPosted: Fri Mar 09, 2007 2:38 pm
thanks. Still have wire management to finish.
PostPosted: Mon May 07, 2007 7:58 pm
Here is Mine :D
http://www.maximumpc.com/forums/viewtopic.php?t=59854
PostPosted: Wed Aug 01, 2007 3:38 am
HARLEY DAVIDSON CASE MOD "HD-1"
PROJECT WORKLOG LINK
Enermax 450W EG465P-Ve PSU
DFI 925X-T2 P4 Mobo
P4 3.2 GHz 800MHz FSB
Thermalright XP-120 & LGA775 bracket
SONY CD & DVDRW (airbrushed)
2GB Corsair DDR2 (4, 512K sticks)
2, 160 GB Seagate Barracuda HDs (raid)
Viewsonic VP171b 17" Thinedge LCD
VGA - ATI|RDN 9600XT 256M 100575L-BK
________________________________________________
CPU STINGRAY
PostPosted: Thu Aug 02, 2007 8:29 am
DFI 925X-T2 P4 Mobo
Wish my uncle was around to see this he would absoultly love it he was a HARLEY DAVIDSON Lover.
R.I.P Eddy.
 Post subject: Re: Biohazard: Toxic Case Mod! (2001)
PostPosted: Thu Aug 02, 2007 12:09 pm
Crimson Sky wrote:
Here's an oldie of mine, more at http://www.thebestcasescenario.com
this is suck a bad ass case man.
