It is currently Mon Mar 02, 2015 9:00 am
 Post subject: WinXP cd-key insertion
PostPosted: Mon Jul 05, 2004 11:44 pm
Bitchin' Fast 3D Z8000*
Does anyone have a link to a how-to for inserting the cd-key in WinXP? Something similiar to what Josetann has on his site for Win98, except for WinXP.
ps... before someone barks about no piracy, cd-key gens, dmca violations, decss source code, pornography, steroids, hashish, heroin or whatever in the forums - I am just backing up my LEGAL copy of WinXP.
 Post subject: Re: WinXP cd-key insertion
PostPosted: Tue Jul 06, 2004 3:08 am
The Logik! Bot
The Logik! Bot
http://www.petri.co.il/activate_with_un ... ations.htm
http://support.microsoft.com/?kbid=291997
Unattended Installations:
http://www.ultratech-llc.com/KB/?File=sysprep.TXT
Suuuure you are. Whatever you say. Jeeez Gadget, you sure put your disclosers in small print!
Google isn't helping. But what about slipstreaming the disc and adding a simple notepad file containing the Serial Number in it? Then just add it in. That way you could explore the disc and get it. I know that's not what you wanted, but it's a possible cure for now:p Not sure if it's possible on XP from the results I'm getting, but I don't see why not.
I'll look some more tomarrow, but even microsoft's knowledge base didn't pop much up that you didn't already know. Lots of stuff to dig through though.
Another 98 site (FYI I guess. only thing that came up thus far)
http://support.microsoft.com/default.as ... -us;263281
PostPosted: Tue Jul 06, 2004 10:21 am
Looks like logik beat you by less than a second :P
PostPosted: Wed Jul 07, 2004 11:38 am
Thanks for the links. :)
