It is currently Fri Feb 27, 2015 12:24 am
 Post subject: Forgetful Quicklaunch in XP Home
PostPosted: Mon Jul 05, 2004 10:47 am
I've tried looking this up on the net but nothing helps. I've gone to C:\Documents and Settings\UserName\Application Data\Microsoft\Internet Explorer and verified that I do in fact have a quicklaunch folder with shortcuts in it. I even added the folder to the default user folder using the same process. My problem is that everytime I start windows I have to manually check the quicklaunch in the taskbar properties. Windows will not remember to keep it checked on the next startup. Is there anyway to get it back to normal so i don't have to manually check it everytime i boot up?
I'm going to guess and say there is a registry key for it but I sure have no clue on where it may be.
PostPosted: Mon Jul 05, 2004 6:57 pm
http://www.kellys-korner-xp.com/taskbarplus!.htm
try some of those, but if you arent comfy with editing the registry, have someone who is do it. bad things can happen.
I think these two will prove most helpful possibly
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoToolbarsOnTaskbar"=dword:00000000
"NoSaveSettings"=dword:00000000
PostPosted: Tue Jul 06, 2004 3:58 pm
Hey thanks! I had to input the second key, but it seems to have worked. I noticed on my last start up that my quicklaunch was back to normal. I'll be saving that tip for later.
