It is currently Fri Jan 30, 2015 10:20 pm
 Post subject: Still No TV on AIW 9600XT:cry:
PostPosted: Sun Jul 04, 2004 4:52 pm
Anyone out there have a clue, and or a fix, for the following error thats generated when I click TV in MMC;
Language Resource file was not found:
C:\Program Files\ATI Multimedia\tv\TVDS???.RSC
Can I do anything thats short of doing a complete reinstall of XP?
Are there any general fixes to this error message or the like. And any other helpful tidbits of info would be GREATLY appreciated!
PostPosted: Sun Jul 04, 2004 7:49 pm
has the TV ever worked or are you installing new card trying to get it working for the first time?
have you followed the instructions here?
http://www.ati.com/support/drivers/winx ... bmit=GO%21
Graphic Driver Version? you do have DX9 and ME 9.0 installed yest?
you may wish to look over at rage3d they have extensive ATI forums (including AIW issues)
PostPosted: Sun Jul 04, 2004 8:14 pm
Yes, the TV did work upon new installation. And then I tried to update everything. I guess IF it ain't broke don't fix it! And I think this especially pertains to ATI, as in All in Wonder cards, at least there software anyway.
I tried a few times uninstalling and reinstalling to no avail.
So it looks like I may burn XP, unless I can weed out the registry, since it is no doubt corrupt. Im not getting any other errors however, and all the drivers appear to be working properly.
PostPosted: Sun Jul 04, 2004 8:33 pm
ah right when stuff works often it is a good idea to leave well enough alone :D
however all may not be lost, you might want to try the steps detailed here
http://www.rage3d.com/board/showthread.php?s=&threadid=33656771
and see if this get you anywhere?
PostPosted: Sun Jul 04, 2004 8:48 pm
Will try! Thanks for the reply! :D
PostPosted: Sun Jul 04, 2004 9:03 pm
ur most welcome I hope it helps :D
PostPosted: Mon Jul 05, 2004 8:48 pm
:D IT WORKS!!!
Anyone that has this problem with no TV (or other similar issues) needs to follow the advice above.
And make sure you have a good reg cleaner to completely clean out all the dead bits of ATI before you reinstall.
Many thanks again maddingo!
