It is currently Sun Apr 26, 2015 11:45 am
 Post subject: simple ocing question
PostPosted: Fri Oct 15, 2004 10:05 pm
if a fast p4 like 3.2 or 3.4 (northwood) would would PC3200 ram be able to oc somewhat?
PostPosted: Sat Oct 16, 2004 1:38 pm
Contributing Writer
Contributing Writer
Depends on the quality of RAM and the luck of the draw on the processor. Generally speaking, you should be able to OC somewhat in that scenario on a 1:1, and more so if you start playing with dividers.
PostPosted: Sat Oct 16, 2004 3:01 pm
Celeron
Celeron
Yes, it'd have to do alot more with the RAM than the CPU. If you get low latency ones, you get a bit of overclocking headroom in them.
PostPosted: Sat Oct 16, 2004 8:31 pm
thats what i thought but wasnt sure bc my friend is ready to build a new rig and wants to do some ocing but didnt want to spend an arm and leg on just ram. so i thought id just ask
bc if you have low timings you can loosem up bust the speed of the ram right?
PostPosted: Sat Oct 16, 2004 10:39 pm
Celeron
Celeron
yes, and most chips with low-latencies are actually supposed to be rated higher (PC3500+), but companies lower the speed rating and dramatically cut the timings.
PostPosted: Sun Oct 17, 2004 5:49 am
Contributing Writer
Contributing Writer
OCZ's PC3200 Platinum is a good example. It's rated at 2-2-2-5, but it's been OCing like a PC4000 stick. The headroom is there if you want to relax the timings.
PostPosted: Sun Oct 17, 2004 2:34 pm
yea thats what i thought, thanks for confirming
