It is currently Thu Jan 29, 2015 5:25 pm
 Post subject: Windows Wont Standby
PostPosted: Thu Jun 24, 2004 2:16 pm
My problem is that since i installed my new radeon 9600 AIW my computer will not go into standby. When you choose standby one of 2 things will happen 1.) everything except the fans will power down for about 10 seconds and then the computer will power back up or 2.) the computer will go completly into standby for about 30 seconds befor it wakes up again. I formated when i installed this card and i am using all up to date drivers. Is there any way to track what it bringing the computer out of standby??
System Specs:
Soltek SL-75FRN2-L
Barton 3000+
Saphire 9600 pro AIW
1 x 512mb ddr400
40gb maxtor hdd
120b seagate hdd
56x cd-rom
onboard sound
Winxp pro sp1
Catalyst 4.4
nforce 4.24
NIS 2004
any help is greatly appreciated
PostPosted: Fri Jun 25, 2004 8:49 pm
Can we assume you've run spybot to be sure there's no offending crapware in your rig?
Can we assume you've checked off standby options in the 'display propperties' part of the control panel?
How's the power settings in CMOS? Maybe reset the CMOS and try again.
Maybe try going into device manager and removing the display adapter AND monitor and let windows reinstall them?
 Post subject: what happens if you try to enter standby in safe mode?
PostPosted: Fri Jun 25, 2004 9:02 pm
Does stand by work if you enter safe mode? It sounds like some program or driver is waking the thing up from standby ???
PostPosted: Mon Jun 28, 2004 7:25 pm
Make sure you've got power management drivers installed if your PC has them. I've run into that with laptops on more than one occasion.
PostPosted: Sat Jul 03, 2004 6:31 am
Since the problem started happening when you installed the AIW card, i bet its the card or driver. Try updating the driver or chaning the card. If it fixes it, it is the card and RMA it or get a new one.
 Post subject: Re: what happens if you try to enter standby in safe mode?
PostPosted: Sat Jul 03, 2004 11:35 am
i would guess that too
does WOL (wake on LAN) disrupt the stand-by? idk, i never turn that on..
