It is currently Wed Jan 28, 2015 1:36 am
 Post subject: WarCraft 3 no-cd crack?
PostPosted: Fri Jul 02, 2004 1:15 am
Will I get my CD key banned for using a WarCraft 3 no-cd crack? How sure are you, and how long have you been using it? Kinda paranoid. Thanks.
PostPosted: Fri Jul 02, 2004 6:20 am
Forum's 3dfx Zealot
Forum's 3dfx Zealot
See talking about illegal things as a no cd crack does break the dcma which would make talking about it against the rules set by the mods and the forum administrator.
If you have an issue with this rule please contact your closest moderator.
PostPosted: Fri Jul 02, 2004 12:58 pm
Nah, he's not asking for info on how to obtain one or anything, he just wants to know if the noCD crack will invalidate his existing CD-key... which I reply to with a resounding NO.
Blizzard is not against CD cracks because they know many legitimate users have them so they don't have to go digging for the CD. That's why they have CD keys in the first place. Even if you have a CD crack, what's the point if you don't have a valid cd key?
They won't deactivate you, don't worry.
 Post subject: Re: WarCraft 3 no-cd crack?
PostPosted: Fri Jul 02, 2004 1:24 pm
BANNED
BANNED
WOW
PostPosted: Fri Jul 02, 2004 9:42 pm
Frankenchrist wrote:
WOW
Jesus Christ.
PostPosted: Sat Jul 03, 2004 5:47 am
No-CD cracks are perfectly leagal if the person using the crack owns the original CD. i would love to get one for UT2k4 for right now cause i broke my DVD-rom :|
PostPosted: Sat Jul 03, 2004 5:51 am
Get the latest patch for UT2004. It doesn't require your CD to play anymore.
PostPosted: Sat Jul 03, 2004 5:59 am
thats good to know, now if only i could install it again
*looks at his dads DVD-ROM*
PostPosted: Wed Jul 07, 2004 4:01 pm
you might have some issues with playing on battle net with a no cd hack. Last I heard they are hit and miss with that. the easiest way I've found instead of using a no-cd hack is to use a virtual drive program where you run from cd images, but now that's coming under attack from copyright protection.
